BLM Locker ?
Old May 18, 2009 | 11:48 AM
lt170chevelle's Avatar
BLM Locker ?
I did some searching and didnt find out what this is used for?Is it just for split BLMs or what? Just wondering what the benifits of using it and what it actually does ?!?
Old May 18, 2009 | 12:13 PM
Kevin Blown 95 TA's Avatar
It's for wide open throttle tuning so that your long term corrections go to 128 and you can add fuel in the enrichment tables and see results based on what you added, not what the correction was before you went WOT..
Old May 18, 2009 | 01:37 PM
ok so i thought blm's werent looked at when wot and was strictly off MAf and VE tables.I am still learning the blms and what all effect them.
Old May 18, 2009 | 05:27 PM
97WS6Pilot's Avatar
If you don't use a blm locker the computer will use the long term corrections from the cell just prior to WOT in its fuel equation. Every time you reflash your computer you reset all the corrections to zero and they must be street driven to relearn. So what happens is you get your air/fuel ratio just perfect on the dyno(or street tuning) and then after you drive it on the street for a while it learns some new corrections and throws off all of your hard work.
Old May 19, 2009 | 07:26 AM
oh ok so is this something you would want to leave on all the time so it will not try to correct? Cant i just go into my constant and change all blm settings to 120? And just to be sure, this would effect a 2 bar open loop tune?
Old May 19, 2009 | 04:00 PM
97WS6Pilot's Avatar
No it won't affect open loop tuning because the BLM's or long term fuel trims are not used in open loop.
Here is some good reading on the pcm modes
http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
Old May 20, 2009 | 08:26 AM
hey thats a pretty good link..nice audio intro too lol..looks like i got some reading to do
alphaauto
Jul 26, 2015 04:40 PM
KGRESOCK
Feb 19, 2003 07:54 PM
95Bird
Advanced Tech
Sep 22, 2002 10:51 PM
LVZ2881
Sep 2, 2002 12:35 PM
Dan K
Aug 28, 2002 12:06 AM
