Pulling Codes
A paperclip.
Should work the same as Shoebox outlines for the 1993 4th Gen's ECM:
http://shbox.com/1/dlc2.jpg
Thanks for the reply. However this did not work. I have the 12 prong type but when I put the paperclip in and turn the key on the SES light just stays illuminated. I would expect it to flash according to the reply. Also the SES light on the 89 is just the words illuminated from behind with a light. With this said the flashing would be what I am looking for correct? As it is not able to give me trouble numbers.
Yes.... the light behind the SES opening should "flash". Count the flashes. If it doesn't flash. the ECM is not entering diagnostic mode. Next step would be to try an OBD-I scanner, like the AutoXray.
Are you sure your SES light is working? Does it light up for a few seconds when you turn the key "on"?
Gtpguy
Jan 26, 2015 04:50 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
