OBD2 to OBD1 do pins need to be changed around?
Old May 29, 2009 | 06:53 PM
mvvette97's Avatar
I'm going to be changing my friends 97 bird to an OBD1 pcm. I know I need to change the knock sensor but is there anything else? I had a guy tell me I will need to swap some of the pins around but I have no idea. Also will I still be able to read codes? I know I will have to use the OBD2 cable but do I need to change the location of the wires in the OBD2 port to be able to work with the auto Xray?
Old May 29, 2009 | 08:36 PM
Why not switch to a 12-pin OBD-I connector. Here are the locations of the wires in the 12-pin and 16-pin OBD-I ALDL connectors, courtesy of Shoebox:
http://shbox.com/1/dlc2.jpg
Old May 29, 2009 | 09:15 PM
mvvette97's Avatar
I guess we could. Does it really matter? I was just thinking if it would work I would just use the OBD2 cable for my scanner. I have all the cables for about every car.
Old May 29, 2009 | 09:43 PM
Is your scanner for OBD-I? Generally, an OBD-I scanner will have a 12-pin connector included. They typically require an adapter plug to connect to the 16-pin connector used in the 95.
Old May 30, 2009 | 12:54 AM
mvvette97's Avatar
Mine is for 1 and 2. It has all the cables. OBD1 cable and OBD2 cable plus chrysler and ford
Old May 30, 2009 | 03:21 AM
RobsWS6's Avatar
This is going from memory but I didn't have to do anything when I swapped a 95 computer in. Also, the resistor was changed in the computer to work for a 96 knock sensor. So all I had to do was change computers back and forth without changing anything else.
Old May 30, 2009 | 05:39 AM
briand069's Avatar
I just did the same thing on my 97. I did the resistor mod on the PCM. Also, I use the OBD I cable for the AutoXray and hook it up like this.
http://shbox.com/1/xraycable.jpg
And everything works fine.
Brian
HectorM52
Jul 30, 2017 11:46 AM
1996LT1Z28
Apr 22, 2015 07:56 PM
sscott
Jan 17, 2015 04:30 PM
Jul 4, 2005 05:00 PM
