going from a obd1 to a obd 2 pcm
Old May 14, 2009 | 09:08 PM
red94chicken's Avatar
would this be worth while if i have a spare obd2 pcm and the required tuning equiptment? i would be on a 94 t/a.
Old May 16, 2009 | 06:22 PM
String's Avatar
Well, all said and done the OBD1 will produce more hp and the OBD2 will produce more torque. Not sure why this is, it just is. I dynoed back to back with the same numbers in each pcm. OBD2 was down about 7hp, but up about 10lb-ft of torque.
Also, unless you plan to run open loop you will need to add some additional sensors, namely a crank sensor and this will require a new front cover. I don't think that the 94s had a maf sensor, so if not you will need one. OBD2 uses a knock sensor and OBD1 doesn't. All of this will require a new or modified stock wiring harness to attach all these new sensors. It is much easier to go the other way--OBD2 to OBD1.
Probably not worth the trouble.
Old May 17, 2009 | 11:01 PM
sbs's Avatar
sbs
Sure, if it saves you having to buy more software. That's pretty much the only reason to do it.
Old May 17, 2009 | 11:02 PM
sbs's Avatar
sbs
Nayr
Mar 3, 2023 08:34 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
