WOT Ignition Timing
Old Jun 10, 2009 | 06:06 AM
sleeperLT1Z28's Avatar
WOT Ignition Timing
For those who do their own tuning, how much total timing do you run at WOT (95-100 kPa)? I have a totally stock engine with Pacesetter LTs and a CAI. I know the stock tables have 38 deg at WOT, I have been running 35. Any input is appreciated.
Old Jun 10, 2009 | 06:48 AM
mzgp5x's Avatar
34*. 15psi blown 383ci/ D1/ 97ss MM6. IC and Meth/H2O Inj. 38* in low MAP range. B.
Old Jun 10, 2009 | 01:47 PM
roguedriver's Avatar
Do you have a boost retard box on there? If not, then thats ALOT of timing, especially if the 34* is whats showing in your table. Thats even higher actual timing since the stock PCM adds a bit.
Ken R.
Old Jun 10, 2009 | 02:07 PM
bobdec's Avatar
My stock and current 4-6K 95-100 KPA are = 35* 100+ KPA = 35*. w/o a dyno tune I have not messed with them, no knock and seat of pants power seems good. Are you sure your stock was 38*
Old Jun 10, 2009 | 05:25 PM
95Blackhawk's Avatar
at 35 you are safe but probably not optimal. Only real way to know is to dyno test. That is how I set my timing for the 383 in my Hawk. You can't use that as a reference because that is a totally different engine but I was running 35 degrees up top at WOT.
Old Jun 10, 2009 | 05:26 PM
Stl94LT1's Avatar
Some of my data logs I see 40-41* at WOT. This is with a custom (by me) tune.
Old Jun 11, 2009 | 01:09 PM
moehorsepower's Avatar
34* even with meth at 15 lbs, You sir have *****
Old Jun 14, 2009 | 09:04 PM
MikeGyver's Avatar
I just glanced at the stock tables for some of the LT1's I've done tuning for. They're all around 31-36 in the 95 and 100kpa cells.
Old Jun 15, 2009 | 06:06 AM
Thanks for all of the replies. My stock tables definitely have 38 deg at 95-100 kPa. I figured I was leaving a little power on the table at 35. Now I will add slowly and see what happens.
Old Jun 15, 2009 | 11:31 AM
mzgp5x's Avatar
Yes, I still got em. Sorry, I don't like to dial back on timing. I've tried it, and, I cannot take the large loss in performance. I do have quality rotating assembly with JE -28cc blower pistons. It is running very good now. I have very good air flow thru the manifold/ heads and have done alot of work on the exhaust side and blower intake. All wheel spin in 1 thru 3, and, off the apex. I have converted to Evans waterless cooling media, and, this helps stop detonation. B.
97Z28Muscle
Feb 6, 2015 10:44 PM
Dzmaro
Jan 25, 2015 10:39 AM
jayblev95
Jan 20, 2015 01:30 PM
Ari G
Dec 11, 2014 03:21 PM
