Cluster not working
Old Sep 17, 2009 | 06:02 PM
86formula's Avatar
Cluster not working
im doing alot of weight reduction and i started removing wires, so far i have removed the cigarette lighter wires, TCS, Airbag, Ebrake, seatbelt, console light, radio (passenger side only so far with the antenna) and alarm sensor thats above the passenger side rear tire. i plugged my gauge cluster back in and my oil pressure and voltmeter are bother working but no temp and no tach (dont know about speedometer because the car still has no seat in it) i traced the tach signal wire from the cluster all the way to the PCM and its still intact. also traced the grounds and theyre good as well. any ideas?
Old Sep 17, 2009 | 08:59 PM
86formula's Avatar
anyone? really need to get this fixed
Old Sep 18, 2009 | 06:47 PM
86formula's Avatar
cluster from the broken car works fine in a different 96 camaro, cluster from that car doesnt work in mine
Old Sep 19, 2009 | 03:12 PM
bobdec's Avatar
86, I only have a '94 service manual, can give you the cluster pin info, but I can't verify if it's correct for a '96. Problem is the working and non-working gauges in your cluster share the same voltage source. +12 ign pin D7, ground pin D8. There is also a +12 V IGn pin C14. Temp comes in pin D3, tach pin D5. Does your idiot lite stay on for oil pressure, or is it just the gauge. Also check gauges indicator should come on if either of the OIL, GEN or TEMP lites are on. It's hard to see but the PCM puts out 50 RPM to the tach with ign on engine off, does the tach flicker when you turn the key on ?
mr28
Apr 20, 2016 05:44 PM
rwferguson43026
Feb 6, 2015 10:06 AM
sdn1997rs
Dec 30, 2014 08:30 AM
mr28
Nov 23, 2014 11:11 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
