Can't Clear History Codes (2 A/C Related)
Old Aug 24, 2009 | 10:05 PM
MarcR94v6's Avatar
I had a SES light the first day I had my car put back together, turned out I forgot to connect one of the electrical connectors to the left oxygen sensor. But I also got "AC Clutch Relay Fault" and "AC pressure fault". Now, I have had my ac deleted all but the compressor for a while now and didn't get any codes then. When I did head gaskets recently I deleted the AC box and put a firewall cover in place of it, but kept the vacuum line to the check valve for Defroster operation. After doing this I now have this code, but only in history codes. I have been able to delete history codes in the past but cannot delete any of the 3 codes I mentioned. Why can't I clear these? And if the A/C codes come back, how can I stop them?
By the way, the scanner is an AutoXray EZ Scan OBD-1 Scan Tool.
Old Aug 25, 2009 | 09:31 AM
bobdec's Avatar
Do you have diagnostics disabled (no X) in the ECM Switch Table for the A/C ? The DTC 61, and 66-71 diagnostics should all be disabled. If you leave the dash switch off of A/C or Defrost settings and reset the PCM, do the codes go away ? How did you disable the A/C, is your a/c relay removed or did you un-plug the compressor electrical connection. It looks like you un-plugged the compressor, but are still running the A/C diagnostics. When you crank the engine the PCM will pick the A/C momentarily (keeps the compressor seals lubricated) this may be throwing the DTC's.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
timmy39120
May 8, 2015 11:41 AM
captcorvette
Mar 7, 2015 12:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
