Question about Pulling Codes on a 1994 Z28
Old May 11, 2009 | 08:25 AM
chya's Avatar
Can the code be pulled but just shorting 'B' to ground ('A')?
When I tried that and turned the key on, my light went off and I heard my fans turn on.
I cant seem to pull the code.
Am I doing it wrong?
Or is something wrong with my PCM?
Or is it not possible on this year?
Old May 11, 2009 | 08:52 AM
2001NBMZ28's Avatar
You need a scanner, '93 was the last year you could jumper A and B to flash the codes.
Old May 11, 2009 | 09:34 AM
chya's Avatar
Ah ok
Thanks for the info.
Old May 11, 2009 | 06:08 PM
Stl94LT1's Avatar
I don't know if the ALDL plugs are the same. But, on a 94 LT1 Vette you can jump these two pins to pull codes.
Old May 11, 2009 | 10:00 PM
Can't be done on a 1994 f-body. As already stated, 1993 was the last year. Not even sure how it could be done on a 'vette, since they use the same computers.
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
