Is the shark nozzle for N20 to close to throttle body
Old Sep 23, 2002 | 10:24 AM
dr97z's Avatar
Well yesterday we took my friends 2000 Z28 to the track for the first time with the N20. The instructions said to install the shark nozzle 2 to 6 inces from the throttle body. (NX wet kit) So we installed it approximately 3-4 inches from the throttle body. We installed a 75 shot to start out with. He purged it at the staging lights, hits it right off the line and it launches then you hear a pop and it dies. He pulls off it starts back up runs fine. Next time out we install a 50 shot and he waits a second off the line then hits it. Seems to be alright. We then bump it up to a 100 shot, he waits a second to hit it, seems to work alright. Next time out 150 shot, waits a second then hits it same thing as the first time, pops then dies for a couple seconds, then he gets it started and goes then hits it again and finishes out just fine. Now on his old LT1 Z, he hit it off the line all the time with 125 shot. A guy in a LS1 vette hits it off the line with a 150 shot. Why is it killing it off the line. One time he didn't even use it and it tried to kill it off the line. Is the shark nozzle maybe to close to the throttle body? The guy in the vette says not to move it back before the MAF with a wet kit because it will make run to rich. Any suggestions comments on what happened are appreciated.
P.S. System has toggle switch to turn on and WOT switch to activate. Tapped into fuel line off the injectors. Did not hit rev limiter.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
