Best rear end fluid/oil
I'll be chaning my rear end tonite, and was wondering if I should go with Mobil 1 gear lube, or just normal Mobil. Due to time and money restraints, I can't order any Redline or other similar products. Just normal dead dinosaur, or Man made synthetic. I'll be using a 3.73 gear if that makes a difference.
One person (derty) suggested that I just use Reg. Mobil....I just wanted some other views on this.
Milo.
Milo.
I use mobil one synthetic, bbut since the change I have noticed a distinct gear whine at ~50 mph when I am off the throttle. I think the synthetics dont have the quieting abilit of the regular dino oils...
I change it every 9m or so and it always comes out nice and clean, inspite of the autocrossing/drag racing abuse.
GM specifies synthetic gear lube in all it's LS1 rear ends. I use Royal Purple synthertic gear lube, it doesn't need the limited slip additive because it's already in the gear lube. I have over 25K on my car now without any gear noise or whine. Do NOT use regular gear lube, use synthetic gear lube only! Make sure the gear lube has limited slip additive already in it or buy GM limited slip additive ($9.00/can - 2 cans required).
Originally posted by DohHunter
Go with mobil 1 synthetic. But pick some GM rear end additive for good measure, can't hurt.
GM tried to sell me their brand of the stuff for $32.00 per quart! (sucker born every day) I ain't one of 'em.
Get the synthetic of your choice, but don't let anyone tell you that a Torsen posi requires any additive like the Auburn diffs with clutches did for many years. My info is that the change took place with the 1999 model year, and the 1998 & older cars still had the Auburn type that required the posi additive.
Good luck. . .
