How do I reset the "Change Oil" light?
Old Oct 5, 2002 | 11:46 AM
94B&RZ-28's Avatar
Question How do I reset the "Change Oil" light?
I know it's easy, just don't know how...
Old Oct 5, 2002 | 12:00 PM
LapeerZ28's Avatar
Owners Manual 6-17: How to Reset the Oil Change Light
1. Turn the ignition key to RUN with the engine turned off.
2. Press the TRIP/OIL Reset Button located on the instrument panel for 12 seconds.
The Oil Change light will start to flash to confirm that the system is reset. The reset is complete when the oil change light goes out.
Old Oct 5, 2002 | 12:07 PM
94B&RZ-28's Avatar
Thanks bro, i knew it was easy.
Old Oct 5, 2002 | 01:22 PM
psychocabbage's Avatar
just note that if you use your trip meter, it will reset that too.
Old Oct 5, 2002 | 01:27 PM
NED4SPD's Avatar
............ since when do we have a change oil light?? Is it on the 2000 and up models??
Old Oct 5, 2002 | 01:57 PM
94B&RZ-28's Avatar
2002 Z-28 M6 #251, B&M Ripper, !CAGS!, C-5 Wheels, BMR Fabrication: SFC,PHR,STB,LCA,Relocation Brackets, Flowmaster Cat Back, Eibach Sportlines, MTI Clear Lid, Holly Power shot filter, Flowtech 3" Cutout, Corvette FRC's, Mobile 1 Oil Cap.
Old Oct 5, 2002 | 05:32 PM
OctaneZ28's Avatar
Disciple
I believe it is on all 98-up cars.
It's pretty useless if you ask me... mine came on 2 days AFTER I changed my oil.
Old Oct 5, 2002 | 05:42 PM
Cobra R's Avatar
It dosnt know when you change your oil
Its based on key cycles and run time for the most part.
eazyZ
Mar 1, 2015 07:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
