X pipe question
Old Oct 3, 2002 | 08:21 PM
99_Z_155's Avatar
Exclamation X pipe question
What size of pipe should be used for an X pipe setup and configuration, and type of muffler or glasspack should i use? (if glasspacks, how long?)
And what kind of horsepower gains will I see?
Also i was wondering if you guys could send me some pics of your x pipe or true dual setup. Thanks guys
Old Oct 3, 2002 | 08:49 PM
maddboost's Avatar
Well first of all LS1s do not have X pipes they have Y pipes. X pipes are generally found on modular motors such as the newer 4.6 litre mustangs. Also glasspacks are no longer used. As for as a Y pipe you need to use one that matches your headers if your using the stock headers a Mac Y pipe would work. If you decide to go with aftermarket hearders each manufacter has a y pipe that matches their headers.
Old Oct 3, 2002 | 09:12 PM
96SFLZ's Avatar
I'm sure he knows that, he's talking about going with a true dual exhaust setup.
I'd probably go with a Dr. Gas 3" X-pipe and try to find a good exhaust shop that'll do the rest. Mufflers...personally, I'd use a couple of Dynomax bullets. I have no idea how much power you'll pick up but if I had to guess, I'd say probably around 15rwhp...maybe more, maybe less
I don't have any pics either but there are quite a few people here running true dual so I'm sure some of them have some pics. Try doing a search.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
onefastgta
Mar 19, 2015 10:10 AM
MadMav
Feb 6, 2015 11:02 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
thenewkid
Nov 18, 2014 12:57 PM
