PDA
View Full Version : Computer Diagnostics and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36
  1. pulling a code
  2. Need a bin file
  3. Just recalibrated speedometer...
  4. where to get LT1 edit
  5. Keyless Entry addition to non-RPO car
  6. what should i get?
  7. programming for dummies
  8. Keyless entry: other CAR MODELS remotes work on my car!
  9. Fuel and Timing with Tunercta.
  10. Gen6 and Gen7 DFI use the same cable?
  11. 96 Obdii:egr & Air Removal........
  12. Where can I get a chip!
  13. Zero out Open Loop AFR tables????
  14. LT1 edit, changin tire size please help
  15. FreeScan CSV files...
  16. Has anyone ever messed with these tables?
  17. Line pressure???
  18. LT1 Highway Mode
  19. Cam LT1 PCM sense boost?
  20. Learing how to tune
  21. OBDII EGR duty cycle
  22. Need a new tuning tutroial
  23. de-tuning hypertech!?
  24. What does this code mean?
  25. Help, I want to start programming.
  26. ls1 edit
  27. Chip
  28. would programming help?
  29. Tunercat for 306
  30. OBD1 conversion
  31. How good are these numbers?
  32. Knock Sensor issues.....
  33. Tunercat PCM Read Error : /
  34. Are BLM boundaries used in Open Loop ?
  35. question about tunercat
  36. Lock the WOT BLM's to 128 on a 93?
  37. I want to start doing my own programming, help me buy what I all need!
  38. Flashing pcm
  39. Does anyone have a gm847 tune A4
  40. programmer question?
  41. Tuning for cc306??
  42. Adapter for OBD1 cable to OBD2 system???
  43. MadZ28.com or PCMForLess.com?
  44. what fuse do i pull to reset my pcm?
  45. opti spark / icm questions
  46. Where to buy LT1 Edit and cable, what kind?
  47. Lt1 Pinouts
  48. Vats mod location
  49. Chip info
  50. Tunercat ?
  51. Computer
  52. any DFI6 gurus care to help?
  53. LT1-Edit: Performance tuning plz help
  54. code 42
  55. Is pcm for less better then Hypertech??
  56. pcmforless, speed density success???
  57. uploading .bin file from A4 into M6 (Bad?!?)
  58. Supercharged 383 BIN/LT1 file
  59. uploading .bin file from A4 into M6 (Bad?!?)
  60. PCM Speed
  61. What LT1 Edit changes after ported heads?
  62. anyone have a modified fuel table that I can try?
  63. maft tuning/scanner help
  64. Data Error
  65. explaining TunerCat options...
  66. just got Tunercat, what should I do?
  67. wiring directions for Fasttrack harness
  68. Would resetting the BLMs do anything?
  69. PCMforless "Dangerously lean" ?
  70. MaStach ALDL cable - will this work for a 93 LT1?
  71. ignition problem
  72. Anyone here have Gen 6 DFI???
  73. OBD-II Programming
  74. Found errors on DynoTune spreadsheet. Please double check your excel file.
  75. upload options, beside lt1edit?
  76. why does my car only run good after i reset the computer?
  77. little help Gen 7 users
  78. 396 tunercat ?'s
  79. Can someone make some sense outta this?
  80. Need to know what these tables are for in tuner cat
  81. Is the tunercat for OBD II coming out anytime soon?
  82. 230/236 bin/lt1 file or tuning help
  83. Everyone with Tunercat, inside please
  84. line pressure
  85. I Need some advice on mail order tune...
  86. Creating Macros for Freescan!
  87. Getting started
  88. Timing Advance
  89. Big Thanks to Ion(MadZ28)
  90. hypertech?
  91. OBD2 Scanning Software
  92. Retrieving codes after OBD2-OBD1 swap?
  93. Speed signal on 87 truck with LT1 & mech. speedo
  94. PCMcomm revisited
  95. Getting Code 11
  96. EDist users inside--->
  97. Looking for Stock 93 M6 Bin File
  98. 94/95 Tunercat burn proms?
  99. maf code question
  100. OBDII / OBDI Laptop cable Conversion
  101. Just bought a laptop now I need software
  102. Accel DFI VII.. questions...
  103. Why can't I access the calibration help in Tunercat?
  104. Will VE Master work with modified BLM boundaries?
  105. need A4 shift table for 4.10 gears
  106. Does edit clear codes also?
  107. OBDII to OBDI conversion?
  108. 10k resistor for pins a&b?
  109. Do I need a special usb-serial port converter?
  110. Datalogged car, -- few observations. Help!
  111. Superior Cable ALDL Cable Connection Question?
  112. $DA2 or $DA3 .ecu files available?
  113. Can someone review my datamaster log?
  114. kPa?
  115. Is there a better Programmer the Hypertech
  116. GMS MAF and Programing questions
  117. Need .bin file for stock cam, LTs and CAI
  118. disabling 3-2 shift solenoid for a dyno run?
  119. PCMcomm and vemaster
  120. computer scanning?
  121. Hitting the rev limiter WTF??? LT1 editor
  122. Question about Computer Diagnostics
  123. Newbie scan/dianostics questions.
  124. Freescan & W2k SP4
  125. Will Datamaster work with Windows XP??
  126. cats problems. HELP!
  127. Help w/AutoXRay PLEASE!!!
  128. M6 Obd1 Vss
  129. OBD1 cable from a local store?
  130. speed density ecm?
  131. Have a couple Comp Questions, (needing a basic 306 Tune)
  132. Reprogramming MASS air versus MAP
  133. What is BLM and is this number bad?
  134. Laptop powered from the Auto
  135. reprogramming is it worth it
  136. Look at my 233/239 timing.
  137. hypertech question
  138. car idles like a**
  139. bad bog
  140. MAF Tabe question
  141. 3.23 auto lt1 shift tables
  142. White Racing FAST harness
  143. White Racing - FAST PnP harness
  144. running rich, help please
  145. Programming tools for '95 3.4L?
  146. Which EPROM '93 Z-28?
  147. How to tune w/t350 to 4l60e
  148. Who sales LT1 edit
  149. software
  150. CAM Tune w/ tunercat
  151. programing for a4 to t56 conversion
  152. best programmer?
  153. ACCEL DFI Vs F.A.S.T.
  154. who has the best rep for mail order tuning?
  155. Burst knock question
  156. Question on Belkin/Com Port Recognition
  157. Question on VATS
  158. Can reason for poor gas mileage be seen from a Datamaster log of car idling?
  159. DTC Code 36 popped up..
  160. After installe heads, car runs slow. Feels weak, throwing codes..
  161. Engine DTC MALF 27: EGR Electrical Fault
  162. will Hooker LT's and SLP Loudmouth give you knock retard
  163. Need a tune
  164. PLEASE HELP!! Keep getting code 16 yet not SES and runs FINE
  165. emissions problem
  166. need help finding cable
  167. wont idle when cold
  168. tunercat or LT1 edit
  169. Performance Mode Switch for LT1?
  170. idle problems
  171. Jet Power Module
  172. Programmer Help
  173. Programmer Help
  174. tuning/diagnostic program
  175. Tech Edge WBO2 log/display Q's
  176. Palm Piliot Programming?
  177. Who can fix my computer
  178. need some type of programmer or chip..changed gears
  179. Calcs-- Nitrous and Inj's
  180. Anyone on Here USE that Dynotune Spreadsheet?
  181. KR when shifting
  182. LT1 engine swiths off??!!
  183. Hypertech ?
  184. Rate your Tune
  185. SES Light Disable
  186. Need some help reading my Datamaster log...
  187. what is a wideband? what benifit?
  188. Correcting Speedometer with TunerCat?
  189. Dyno Run: How much Knock Retard will effect performance???
  190. can't get IAC counts down
  191. can you use tunercat to change closed loop fueling?
  192. 01 Camaro SS - ECM pin assignment
  193. Tuning for power with bolt on's?
  194. Very poor low end after new cam
  195. Car runs fine, but cannot read PCM
  196. how do you read free scan logs?
  197. logged a few runs, have a few Q's
  198. dfi units
  199. Diagnostic Software for ODBI conversion
  200. All I need to start using LT1 Edit??
  201. Service Engine Soon Light
  202. wiring fog lights
  203. pcm idle
  204. Scanner readings???? Help
  205. LS1 edit
  206. Can someone tell me what size these injectors are??
  207. tranny not shifting after FAST install stuck in third
  208. so confussed, someone please help!
  209. PCM edit help for +sized tired and rear o2's
  210. ?s on making a OBD1 scan tool connect to my OBD2 connector (95Z)
  211. Removing VATS
  212. Will A/C not working give me a code?
  213. Lt1 computer tuning, cant get ahold of Ion(madz28)
  214. Car tuning issues
  215. Trouble code help
  216. couple questions
  217. Computer tuned with bad TB,fixed now car runs rich.Questions.....
  218. air and egr
  219. AFR after startup
  220. speed density or maf
  221. corvette gauge swap
  222. software
  223. diablosport predator?
  224. lookin for some programming help...
  225. help with bin file
  226. scanner data
  227. Can a OBDII be reflashed to become a OBDI?
  228. Which side is right bank?
  229. pcm programming?
  230. First things to do for a performance tune?
  231. OBD1 swap info
  232. Winaldl file..please read it for me!
  233. Hypertech or or Jet PCM?
  234. VATS System Problem? Car Wont Start
  235. 95 obdI with obdII style connector
  236. Wide band O2
  237. Autotap - Enhanced or Generic?
  238. Got A Question for Madwolf "Ion"
  239. What Software Choices?
  240. USB port for cable
  241. True that OBDI cars make more power than OBD2?
  242. Radar Detectors, City Vs Highway use.
  243. how do i tell if my cable is working
  244. Yellow "REF 3x" wire from crank sensor
  245. Extremely low vaccum after cam change!
  246. Need FAST help fast
  247. TUNER CAT question
  248. A/C compressor not coming on?
  249. Freescan Readings - Big Vaccum Leak only Sometimes?
  250. Which Mail Order Tune to go with?
