Car tuning issues
Old Mar 24, 2004 | 02:01 PM
ramermanz28's Avatar
Car tuning issues
Ok computer tuning gurus. I have the 95z in the signature. Mods are 6# Vortech, comp cam 224/236, 58mm AS&M TB, AS&M 1 3/4" headers, P&P stock casting heads(no flow #'s), 1.6 comp pro-magnum RR's, no EGR or AIR, no CAT. I've had Bryan at PCM for Less write a program for those mods. He has re-written it three times to try and get the car running right, so far no luck. Once it goes into closed loop it runs rich and causes the plugs to foul. The car runs very strong but I know I can squeeze more power out of it with a good tune. I had it dyno'd with the first program and it netted 340RWHP! That's horrible for what has been done to the car. Can anyone help me get this figured out. I have Datamaster and Tuner Cat. I can send anyone the Data run so they can see the problem I am having. Thank you very much for your help, Rob.
Old Mar 24, 2004 | 10:34 PM
Dan K's Avatar
Not entirely sure I can help, but I'm always willing to take a look at a datalog to see if anything sticks out.
Old Mar 25, 2004 | 02:02 AM
Botch's Avatar
Put your MAF on the pressure side. I had the same problem. Trust me it will fix it. The surge valve jacks up the MAF signal and it will add fuel to compensate.
Botch
Old Mar 25, 2004 | 10:31 AM
jdizzell's Avatar
You said that you had your car dynoed, why not dyno tune it there?
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
97SSdude
Dec 31, 2014 07:43 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
