Tunercat PCM Read Error : /
Old Apr 22, 2004 | 10:42 PM
Vomit God's Avatar
Question Tunercat PCM Read Error : /
I've got a 94Z.
I've got TC 2.0
Made my own cable.
Using it on a (VERY) old laptop.. (133MHz.. other specs avail. if needed)
Other programs get raw running data.. (speed, rpm, temps, spark, blah)
But when I try to get the PCM's contents, TC gives me a "PCM Read Error"...
It did this on mine, so I checked it on my bros. 95 TL1 B-body.. Same error..
Is there something I should do to / check on the laptop (com port setting??) or should I just try it again using my PC (which is MUCH more powerful than the laptop)?
Could it be the cable?
I've used a "newer" (466+ MHz CPU) laptop with something a long time ago to get the contents, and it worked with the same cable..
All input is appreciated..
Thanks in advance!
(BTW.. what are TC's minimum sys requirements?)
Old Apr 25, 2004 | 12:02 AM
Vomit God's Avatar
So not a single person here has had this problem??
Old Apr 25, 2004 | 10:10 PM
ru2slo_99's Avatar
I had the problem with it not reading. I had to turn off the anti-virus.
Old Apr 25, 2004 | 10:20 PM
Tails's Avatar
Make sure you have all the background services off on the pc. Antivirus, screensaver, hibernation, etc...
Tails
Old Apr 25, 2004 | 10:35 PM
Vomit God's Avatar
Thanks guys..
Every feature is off..
It's a bare minimum install of 98SE on the laptop now..
Still gives the error..
I wrote it down wrong last time..
The error is actually:
"Invalid responce from the PCM. Press OK"
Then:
"Resetting PCM"
Then:
"PCM read error. Press OK"
I've used another program a long time ago that made a bin of the PCM(or so I think), does anyone know of any PCM dumpers? Is TunerCat's "PCM dumping only" program free?
If one works, but not TC 2.0, It's got to be the laptop.. I havent had the time to check with my (this) PC.. : /
FreeScan get's all the data live when the engine is running.. I can understand the differences of transmitted data, and getting raw "PCM data" only.. But why would only one work?
Thanks again guys
Old Feb 24, 2007 | 03:43 PM
joking78's Avatar
I know this is a couple of years old but this the same problem that I'm having.
Can any one help??
Old Feb 24, 2007 | 04:13 PM
VinceTrifecta's Avatar
I have an OBD1 tester application that might help us determine what the problem is. Pls send email if you are interested.
Vomit God's Avatar
It actually turned out that I had a bad ground connection.. I was using 12V and ground from the lighter socket, but I found that if I use the ground in the ALDL connector, it worked great! I could read on both my car and my brother's b-body. (And I wrote back to my PCM after editing it) I hope that helps.
Old Feb 24, 2007 | 04:14 PM
Another forum member was running into similar problems and his PCM was reporting a low-voltage condition. The PCM will refuse to be read or perform a write if the system voltage is low.
Old Feb 24, 2007 | 04:17 PM
Vomit God's Avatar
That is another good direction to look.. Charge your battery over night, and be sure to have a good ground..
Old Feb 24, 2007 | 04:18 PM
joking78's Avatar
I'm using the lighter connection aswell but wont even try if I unplug it.
Old Feb 24, 2007 | 04:23 PM
Vomit God's Avatar
Yeah.. did you make your own cable? if so dont be afraid to hack it up. Pin A is ground (for 12 pin) If anything make a converter to plug your Cig lighter into, an branch the ground to pin A, and 12V+ to the cig lighter socket..
Old Feb 24, 2007 | 04:36 PM
joking78's Avatar
No I got one from aldl I see next to the serial plug there is a red connector that looks like you could connect two wires if you had a plug to plug in it. I'm looking for something to connect them with now!!!
Old Feb 24, 2007 | 04:47 PM
joking78's Avatar
Well that didnt work ether
Old Feb 24, 2007 | 04:52 PM
joking78's Avatar
As soon as I put a paper clip in it the fans came on!
