A/C compressor not coming on?
Old Mar 17, 2004 | 05:57 PM
AW/whiteZ-28's Avatar
I checked the relay its fine. I checked the compressor it isn't stuck. I used a jumper wire and it came on like that, so I have narrowed it down to the power wire that activates the relay. But, is there something else in line to the relay that could be messed up or am I gonna have to replace the entire wire?
TIA
Archie
EDIT: Is this thew right forum or should I be in LT1 Tech?
Old Mar 17, 2004 | 08:09 PM
LiT1_up's Avatar
Check for pressure in the system.
Old Mar 17, 2004 | 08:49 PM
It's got pressure
Old Mar 17, 2004 | 09:01 PM
LiT1_up's Avatar
Checked your fuses?
Old Mar 17, 2004 | 09:07 PM
Yep they're good
Old Mar 17, 2004 | 09:38 PM
LiT1_up's Avatar
Try turning on the defroster and see if it comes on then. If that doesn't work, check and see if there are any trouble codes that will not allow the ecm to enable the a/c compressor relay.
Old Mar 19, 2004 | 01:43 PM
The defroster thing didn't work but I'm reseting the computer right now if that doesn't work I got a buddy with a shop I can get the code(s) pulled at
Thanks for your help
-Archie
Old Mar 20, 2004 | 04:15 PM
Fbody1's Avatar
I had the same problem last year , it was a wire behind the pcm ( under the hood ) that went to the temp sensor in the dash , somthing rubbed it , or caused it to break , so check that wire I dont rember the color of the wire , but look a sensor w/wire behind the glove box( you have to remove a plastic pice to see it) a big one
Old Mar 20, 2004 | 06:52 PM
thanks I'll check that out too
Old Mar 20, 2004 | 07:02 PM
Clary's Avatar
a/c compressor not coming on
I had this problem with my 95 z28 and my sts cadillac .Just disconnect the battery cable for a few minutes,this is what i did and my compressors came on .I think and over tempertature code or something set in the pcm.I hope this helps.
Clary
Old Mar 22, 2004 | 08:35 AM
Highlander's Avatar
There are some scanners that will not check the A/C low pressure code nad that code must be deleted if you had previous problems.. I suggest (to leave doubt out) disconnect the pcm for a few mins... A FEW!
Old Mar 22, 2004 | 06:56 PM
BlackDog's Avatar
Not to be smart or anything, but how do you know you have pressure? You can have pressure but still be low enough so that the compressor won't come on.
Old Mar 23, 2004 | 06:39 AM
Clary's Avatar
I installed my a/c test gauges on both cars pressure ok
HectorM52
Jun 23, 2016 08:42 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
