Cam LT1 PCM sense boost?
Old Apr 25, 2004 | 03:27 AM
LT1RX7's Avatar
I know there is a MAP sensor on the the engine but does the PCM actually read boost, or is it basically for vacuum? I have an LT1 edit program and nowhere do I see any tables for the MAP sensor. Can someone help me out?
Old Apr 26, 2004 | 04:26 PM
arnie's Avatar
Re: Cam LT1 PCM sense boost?
Originally posted by LT1RX7
....but does the PCM actually read boost?
As the mapping is set up in the software, no. Code would need disassembly, and the tables, as relating to kpa, would need remapping/hex editing.
Old Apr 26, 2004 | 09:02 PM
Ricardo's Avatar
You can use a two or three bar MAP sensor and scale the timing tables and other MAP related variables proportionally to make it work. You will loose resolution however. It has been done. Search the archives of the LT1 edit forum. You will find more info in there.
Old Apr 26, 2004 | 09:52 PM
arnie's Avatar
Originally posted by Ricardo
You can use a two or three bar MAP sensor and scale....
A ? was asked, and I answered correctly. Yes, what you have stated, has been exercised. However, that is not fixing the problem, of the pcm code not recognizing/accommodating boost. It is only masking the problem, unfortunately.
Old May 29, 2004 | 11:42 PM
Highlander's Avatar
There is a guy that did the dissasembly and the PCM senses boost correctly.. it uses a 0-190kpa timing table and the such...
On the other hand...
If we used a 2 bar map sensor and we "tuned" around it...
Can we have more than 100 on the VE Table???? or it would be the best idea to run in SD and then scale EVERYTHING by half... VE table by half and injector constant by half.. that way.. 100 in the ve table would mean actual 200%.
You would have fueling for "part throttle" boost and the WOT would be done on the enrichment part...
possible?
Old May 30, 2004 | 12:08 AM
tjwong's Avatar
Don't forget that the PCM gets its baro reference upon key on when the PCM first powers up. When you replace the 1 bar map with a 2 bar map this function is going to be inoperative and will set a DTC.
Old May 30, 2004 | 12:10 AM
Highlander's Avatar
Do you have msn messenger??
that error can be disabled with TC.
Old May 30, 2004 | 12:23 AM
tjwong's Avatar
Yes the DTC can be disabled with TC or possibly LT1 edit but that doesn't make it correct because the PCM still will not get its baro reference.....
I have AOL instant messenger, my screen name is: twong29770
Old Jul 19, 2004 | 06:56 PM
ScreamnChicken's Avatar
NOOOOOO dont keep this info secret I too am looking at using a 2 bar map for a forced induction application.!!!
What did you come to for a conclusion???
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Injuneer
Dec 15, 2014 09:36 AM
