Getting Code 11
Old Apr 14, 2004 | 08:17 PM
southern78's Avatar
Getting Code 11
I am using LT1 edit and used free scan to read Code 11 off the PCM. I am not sure why its throwing this code because the bulb for the SES like is good inf act it stays on. What could be causing this.
By the way the a 95 z28 LT1 in a 88 s10 blazer.
Old Apr 17, 2004 | 10:10 PM
1996SS's Avatar
i got the same code in my 69 chevelle (lt1 m6)
code 11 which is a malfunctioning indicator light
fans will come on at start up
fix
i install a small led indicator light for DTCs
i can't remember which pin
Old Apr 17, 2004 | 10:19 PM
southern78's Avatar
That would help me ALOT if you could find out which PIN or wire I need to run a LED off of to fix this.
Thanks,
Howard
Old Apr 17, 2004 | 11:22 PM
1996SS's Avatar
check blue D9
Old Apr 18, 2004 | 02:41 PM
southern78's Avatar
I checked Blue plug pin 9. It is cut and leading to nothing. Can I run it to the SES light in my dash also? Will that stop the problem?
Old Apr 18, 2004 | 06:25 PM
1996SS's Avatar
I run it to the SES light in dash from (blue )pin 9
it work for me
Old Apr 21, 2004 | 04:53 PM
southern78's Avatar
Wouldn't know what other PIN outs could cause would ya? I tried jumping that wire into my SES light on the dash and nothing. I reset the codes but it comes back on and brings the fans on.
Old Apr 21, 2004 | 07:24 PM
southern78's Avatar
Never mind. You were right. Some how had it wired wrong leaving the cluster. Just ran another wire to D9 from SES cluster feed. Works!! Thanks a million :-)
Old Apr 21, 2004 | 08:43 PM
1996SS's Avatar
glad to be helpful
i had the same problem on my 69 chevelle lt1 m6
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
