can you use tunercat to change closed loop fueling?
Old Mar 28, 2004 | 03:12 PM
Fbody1's Avatar
car runs rich when I am driving ( like a normal person) is ok under wot, need to change part throttle fueling too rich, black stuff all over rear bumper , still gets 20 to 22 mpg , what to use in tunercat to help this?
Old Mar 28, 2004 | 06:10 PM
ZPaul2Fresh8's Avatar
If it gets 20-22 MPG, then it seems good. The black stuff on your bumper is probly built up carbon from the exhaust.
Generally with MAF cars you'd change the MAF Tables I *think*. I'm not certain since I use Speed density.
Old Apr 1, 2004 | 07:28 PM
Fbody1's Avatar
why is there so much carbon in the exaust, is that normal ( no cat ) what can I do about it , I'm using the stock maf( de screened) am I at the limits of tunercat. where to look next?
Old Apr 1, 2004 | 10:04 PM
Schurters LT1's Avatar
I had the same thing, but when i tuned the car on the dyno and made the changes to the wot fuel and did the same to the coolant table +/- the tables it cleaned it all up...when you do the coolant table wot you do the hole tale +/- ...so your fuel is right no mater what temp you are at..
my maf tables are stock.....
DirtyDaveW
Dec 1, 2016 05:37 PM
blac94Z
15
Mar 2, 2015 12:00 PM
armedtrigger
Feb 24, 2015 08:30 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
