What LT1 Edit changes after ported heads?
Old Apr 19, 2004 | 05:01 PM
rpm4lalo's Avatar
I have the following combo dynotuned with LT1 Edit:
cc306 with crane 10308-1
1.6 RR and comp R lifters
1 piece pushrods with GM guidplates
jet hot longtubes into dual 3 inch exhaust
electric H2O and ASp crank and alt pulley
stock heads, stock TB and stock intake
Moroso CAi and ported MAF
4.10's and Mcleod single disk clutch.
!AIR, !EGR, !CAGS, !CATS
My 95ta dynoed out 354rwhp and 352 rwtq with 12.7:1 AFR
I ported the heads, having them cut for 2.00, 1.56 valves, 3 angle valve job.
I am adding a 52mm TB and increasing the roller rocker ratio to 1.65.
I am adding 30# injectors.
When I get the car together what changes should I make with LT1 edit so I can drive it until I can get it redyno tuned for thew new combo???
Old Apr 20, 2004 | 10:51 AM
rpm4lalo's Avatar
I don't know how I forgot to mention that it has stock bottom end and that I spray a 125 wet shot of nitrous on top of all this.
Thanks Again.
Old Apr 24, 2004 | 09:50 AM
Dan K's Avatar
I would guess that you might want to throw a little more fuel in it until you get it back on a wideband.
Oh, change the injector constant and possible offsets for those 30's.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
