Dyno Run: How much Knock Retard will effect performance???
Old Mar 28, 2004 | 05:50 PM
ZPaul2Fresh8's Avatar
Results: 320rwHP/331rwTQ
LT1/A4: Hotcam/CAI/Exhaust/Longtubes
While getting my car dyno'd I logged both runs.
Now each run at one point had knock retard of 0.7, so my spark advance fell from 42 to 37 degress when this happened.
I thought generally when this happens it will effect the engines power dramaticlly, but didn't see any spikes on the dyno graph.
So I was wondering if I'm losing any potential HP due to the spark retard?
And if this is actual knock, should I fix this by decreasing advance a few degrees in the areas needed(RPM 4200/MAP 100)?
Thanks.
Old Mar 29, 2004 | 02:14 PM
LT4ultraZ's Avatar
Are you using a LT4 knock modual?
Old Mar 29, 2004 | 04:23 PM
Oops, I forgot to mention I have a 93, no need for LT4 KM
Old Mar 30, 2004 | 08:53 AM
LT4ultraZ's Avatar
first if i was you i would try and use 100 octaine and see if the knock is still there. If if is then it is false knock. I ran that same setup for a while and 42 is a little high for 4200 and 100 kpa. try 40. That cam will make good increases in power till 6300 rpm and maybe higher but i would not go over 6300.
Old Mar 30, 2004 | 07:58 PM
Thanks for the reply. I only dynoed to 5700, I wonder how much more power I could've made...
Next time, I will go and use race fuel... then timing.
maybe2fast
Mar 16, 2015 11:59 AM
Chrisdude
Aug 14, 2002 06:30 PM
DarkHorse
Aug 3, 2002 10:17 PM
