logged a few runs, have a few Q's
Old Mar 27, 2004 | 10:45 AM
OpCode's Avatar
95 T/A 3.23 A4
the logs show the max airflow @~5900RPM thats peak HP right??
also in datamaster the 2>3 shift takes about 13 Recs@10 Rec/Sec
or 1.3 Secs to complete(right?)
is that saying my trans is going or do i just need to up the line PSI
before the shift.
thanks
Old Mar 27, 2004 | 01:11 PM
94redform's Avatar
I have mine turned up to 115psi, but you have to go into the constants table and turn the maximum allowable psi up or it's just gonna max out at whatever that setting is. And how many miles are on your tranny, I replaced mine at 124,000 because the 1-2 shift was slipping just a little bit. I had to have my new one rebuilt again because it was shifting really slow 2-3, there was a plunger that had some play in it and it was causing pressure to bleed off. The 3rd gear clutches took a beating from it too, a couple of them were down to bare metal.
jeff94z28
Sep 11, 2002 02:01 PM
Stumper66
Jul 9, 2002 01:42 AM
2_shady
Jun 30, 2002 11:24 PM
