Just recalibrated speedometer...
Old Apr 28, 2004 | 09:00 AM
LiT1_up's Avatar
for new gear set and now tranny won't shift at 100% tps. anybody got any ideas about what other tables might need tweaked? i'm using tunercat to make adjustments.
Old Apr 28, 2004 | 01:51 PM
Eff's Avatar
Eff
Re: Just recalibrated speedometer...
So it WAS shifting at WOT before you fixed the speedometer? I'd try calibrating it again. To the best of my knowledge you shouldn't need to change anything else. If all else fails you could try loading a stock profile. What size gears did you go to anyway?
Old Apr 28, 2004 | 04:31 PM
97Z-M6's Avatar
you have to go in a SCALE the normal shift table. alll you ahve to do is open the table, highlight the whole table and right click on the table and choose scale, then enter the number to scale by.
here how you get the number--- old gear divided by the new gear.
EX. stock 3.42 / new 4.10 = .8341 scale number.
Old Apr 28, 2004 | 04:38 PM
LiT1_up's Avatar
yep. it shifted fine after swapping the gears and before changing the pcm. after the recalibrate she won't shift at wot. but if you let up on it a bit it will shift. originaly had 2.73s, updated to 3.42s.
Old Apr 28, 2004 | 04:50 PM
97Z-M6's Avatar
scale by .7982
Old Apr 28, 2004 | 07:35 PM
LiT1_up's Avatar
i did exactly as you instructed 97z-m6, but it didn't help a bit. anymore ideas?
Old Apr 28, 2004 | 08:30 PM
97Z-M6's Avatar
email me your bin file.
your bin file.
vincentbergeron@yahoo.com
Old Apr 28, 2004 | 09:25 PM
97Z-M6's Avatar
do you have a stall if so how high
Old Apr 28, 2004 | 09:43 PM
LiT1_up's Avatar
no stall
Old Apr 28, 2004 | 09:56 PM
97Z-M6's Avatar
i figured it out. should work now.
i sent it back fixed
Old Apr 28, 2004 | 10:41 PM
LiT1_up's Avatar
thanks a bunch. i'll let you know how it works out.
Old May 1, 2004 | 02:47 PM
LiT1_up's Avatar
it is fixed.
Old May 2, 2004 | 10:05 PM
Eff's Avatar
Eff
Well.... What was it?
Old May 3, 2004 | 08:04 PM
LiT1_up's Avatar
scale the tables in the kickdown and hot kickdown modes up/down shifts points.
Meccadeth
Feb 16, 2004 07:42 PM
lt1coz
Parts Wanted
Oct 9, 2003 02:36 PM
cz28s
Sep 5, 2003 12:57 PM
93FBIRDFORMULA
Aug 23, 2003 09:36 PM
silicuda
Pacific
Mar 7, 2003 10:15 AM
