question about tunercat
Old Apr 22, 2004 | 05:14 PM
greatwhitez's Avatar
Hello, i have a 95 lt1 396 w/ gm 847 cam and so on, i found an Lt1 edit file on Bfrankers webstie, http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
my question is, it says lt1 edit file, is there any way to use this with tunercat? if so how, or if not how can i get the baseline tune for my 396?
THanks,
Nick
Old Apr 22, 2004 | 08:52 PM
LiT1_up's Avatar
you can open lt1 files with tunercat. in tunercat under the file tab click open and choose the file you want to open. then at the bottom of the of the pop up window change the file type from bin to lt1 and click open.
Old Apr 23, 2004 | 12:52 PM
sounds good, thanks for you help! I'll let ya know how the tune goes, its my first real tune, so im gunna take my time. Hoping to just get a good base tune, then adjust from there. Anything special i need to look for or do.. saftey precautions or anything.
Thanks,
NIck
Old Apr 23, 2004 | 01:20 PM
Jon A's Avatar
I'd verify the basic things are correct before running the car--things like injector constant (he may have been running different injectors), etc.
BigWil
Mar 29, 2015 12:24 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
