Which side is right bank?
Old Mar 21, 2004 | 11:21 PM
JSK333's Avatar
OK guys, I've always thought that cylinders 2,4,6,8 were the right bank. Is that correct?
I am having good success tuning with the individual cylinder fuel trim tables, and seem to be seeing the opposite of what I expect (removing fuel from cylinder 2 makes the right bank richer).
Does anyone know for sure?
Old Mar 22, 2004 | 05:07 AM
BlackDog's Avatar
Re: Which side is right bank?
Yes that is the right bank. The way I understand it removing fuel from a cylinder will make that bank go richer because the o2 sees a lean condition.
Old Mar 22, 2004 | 10:47 AM
JSK333's Avatar
Re: Re: Which side is right bank?
Originally posted by BlackDog
Yes that is the right bank. I way I understand it removing fuel from a cylinder will make that bank go richer because the o2 sees a lean condition.
But if that bank is already running rich (BLMs < 128), then shouldn't it run leaner once fuel is taken out?
I'm going to keep experimenting.
Old Mar 22, 2004 | 04:22 PM
BlackDog's Avatar
What's your BLM's reading? Also check to see if you have an exhaust leak, see this thread.
http://web.camaross.com/forums/showt...hreadid=205583
Old Mar 22, 2004 | 04:32 PM
JSK333's Avatar
It varies, but the right bank is generally 3-5 steps lower than the left is: like L128 R123.
I have stock manifolds, but I'll still check for any leaks. Thanks for the thought.
Old Mar 22, 2004 | 06:50 PM
BlackDog's Avatar
What kind of reaction do you get in regards to ajusting your throttle blades i.e. opening and closing them. Do the BLM's get closer to 128?
TheGreenZ28
Oct 4, 2020 11:29 AM
eagle54348
Jun 15, 2015 05:00 PM
nosliw
Feb 7, 2015 01:30 PM
siguy
Nov 27, 2014 10:07 AM
