Palm Piliot Programming?
Old Mar 30, 2004 | 06:23 PM
Schearer225's Avatar
I got a Palm IIIc. I was wondering if i could use this in anyway in programming/diagnostic's in my 95 Z28. Just curious.......... and if i can, where do i get more info about this?
Old Apr 1, 2004 | 04:15 PM
Tires_Smokin's Avatar
I have a T3 Palm and an older Vx Palm. I'm using Autotap for my scanning. You might want something else but I'm just giving you some insight of what will work with your Palm. To find out if your Palm will work with Autotap, call Auotap's technical line. But actually, If you turn on your Palm, access your applications directory. "Tap" on Info and scroll down until you see "system". "Tap" on the version button. The above header in this menu should read Palm OS software version ??? (e.g My older Palm is version 3.5.2. Autotap says that Palm devices with version 3 or higher will work fine. My T3 Palm is version 5.2.1, so that will work even better with it's higher processor and Ram. Use the selected adapter that they offer on their website or use the universal. T3's is what I have, you need a universal cable for it.
Hope this helps..
Autotap
Old Apr 1, 2004 | 06:21 PM
moparman's Avatar
I was just looking at Autotap's site, and think they can fix you up.
Old Apr 1, 2004 | 07:34 PM
OK thkas alot i will give that a look
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
