PDA
View Full Version : Exhaust System
Pages : 1 2 3 4 5 6 [7] 8 9 10 11
  1. Stainless CME
  2. How to stop leaking headers at flange?
  3. Pacesetters don't fit right (94' LT1)
  4. Is there any way to buy a Corsa Muffler?
  5. which cat-back??
  6. Open 12pt Wrench to Access Header Bolt?
  7. turn down
  8. EGR block off plate-- tune computer
  9. What exhaust are you running with BMR's Trak Pack?
  10. Anyone With Mac Mids on an LT1 get in Here Please
  11. I have an odd Exhaust question....Please help
  12. 97 SS which Pacesetter LTs?
  13. Summit c/o?
  14. Exhaust to loud.
  15. Hok 16765
  16. question before i order..
  17. Is there a gain replacing the muffler on my stock catback?
  18. Full bore muffler
  19. Hooker catback rattle
  20. Finally they go on
  21. Flowmaster Catback on a 98 Z28
  22. Problems After Header Install
  23. stock pipping and a muffler question
  24. E-Cut Out !!!!!!
  25. Your thoughts - exhaust or none - turbo
  26. no heat shields a problem?
  27. as&m headers
  28. vid of my exhaust
  29. Header, Y pipe, and cat ?'s
  30. Magnaflow Quad Tip Exhaust Pricing
  31. Custom Dual Exhaust
  32. stock y-pipe replacement
  33. Exhaust questions (in CA)
  34. Cone Of Silence
  35. Lets see your Longtube clearance with lowering springs
  36. o2 sensor question
  37. Question After Header Install
  38. American Racing Headers
  39. Fixing exhaust leaks.
  40. Summit brand turbo mufflers: Are they restrictive?
  41. single dumped bullet
  42. Pacesetter/Hooker and Mufflex question..
  43. Header Heat..
  44. Cats for my exhaust (GMMG, Pacesetter)
  45. Muffler Question
  46. 3rd Gen header install??? cutting parts off?
  47. Stainless Works?
  48. exhaust help for drag car
  49. large, single, loud muffler
  50. Magnalflow muffler for true duals....
  51. cooked wires
  52. O2 sensor ruined. Can i drive it unplugged?
  53. Please Help
  54. GMMG or stick with my current Cat-back?
  55. LM1 and LM2
  56. Will bead blasting remove Jet Hot coating?
  57. SLP 2otl
  58. Oval exhaust pipe
  59. cheapest chambered muffler (gmmc style)?
  60. 3rd Gen Exhaust System
  61. replacing aftermarket cat for stock one-po420
  62. I feel like such a......
  63. Best V-6 Muffler?
  64. New exhaust for 2000 SS
  65. got my car back with cut out
  66. How can I tell if my CAT is clogged?
  67. I have a 383 with LT headers, no cats.....What muffler should I get?
  68. SLP loudmouth OR BORLA
  69. totl
  70. Headers
  71. how to connect y pipe to catback?
  72. Anyone ever put a muffler were the stock one would be on an slp lm catback?
  73. Help installing Pacesetter Headers
  74. Dropping the y pipe?
  75. were did you mount you wideband O2
  76. Straight pipe same as cutout?
  77. GMMG people
  78. Got CME on with Magnaflow Catback
  79. Pacesetter LTs + Texas True Dual Qs
  80. Where to get dual tips w/ 2.5 inlet??
  81. No more Emissions!
  82. Want to add my cutut and upgrade exhaust.
  83. Video of my home made exhaust..
  84. Stock -> FULL exhaust LT1 dyno numbers?
  85. Hookermouth. Anyone ever try this?
  86. MAC discontinuing catted-Y???
  87. Stock Slp
  88. Loss of low end power after header install
  89. Blew the guts out of my Dynomax bullet muffler
  90. Flowmaster American Tunder 17199 questions
  91. O2 Sensors Help / Check engine light
  92. Best fitting LT1 headers
  93. Just looked under my car and...
  94. Help
  95. Proof of the best Y and LT set up!
  96. Header Gasket Port Size
  97. cut outs
  98. Need to replace my catalytic converter...
  99. Guys/Gals with Magnaflow catback...
  100. How bad are warped header flanges?
  101. where to put cats in y-pipe???
  102. O/R y-pipe? worth it?
  103. True Duals
  104. The final product...still good gains?
  105. LT1 Stainless headers poll
  106. uncoated headers wrap or paint?
  107. any body know who this is?
  108. SLP 2OTL exhaust.
  109. daily driver: what is most non rice sounding muffler for ecotec
  110. Clean-slate exhaust--What am I missing?
  111. Air line differences?
  112. Will a 01 WS6 stock cat-back fit on a 95 Formula?
  113. where to buy stock 95Z cat-back?
  114. Magnaflow lt1 to ls1
  115. Muffler
  116. tsp rumbler guys come in.
  117. Long tubes hit motor mount
  118. exhaust bolt size
  119. what should i expect from this set up. (LT1)
  120. New brand of LS1 headers, OBX. Thoughts?
  121. What are BBK shortys worth for a LT1 f body?
  122. keep shorties. go duels and lose cats?
  123. Replacing cat w/ straight pipe?
  124. enlargening header gaskets
  125. Anybody have Camaro Magnaflow pics?
  126. Percy's XX Carbon Header Gasket ?'s
  127. Hooker Exhaust?
  128. Donut Gaskets for 93-95 SLP Shorty headers
  129. Adding a cat to a LT setup
  130. Sealing 2 piece jethot primary?
  131. cat removal
  132. Magnaflow Opinions?
  133. Long tube question
  134. Midlength 93-95 headers on 97 SS with 2OTL
  135. Fixed 2 bad exhaust leaks with foil
  136. No Muffler...Cat only
  137. Cherry Bomb
  138. stock gasket vs header gasket
  139. Dilemma
  140. Long Tubes + Modified Y-pipe with Cats
  141. hooker super comp. sidmounts
  142. t/a exhaust
  143. collector diameter on Jet Hot??
  144. exhaust setup for a Procharged 383 with TFS/ported LT1
  145. Best place to buy DMH cut out?
  146. Where does most of the stock manifolds leak from ?
  147. Exhaust size and HP?
  148. slp adaptors
  149. Y pipe for edelbrock shorties ???
  150. Edelbrock catback exhaust for LS1
  151. 1 7/8 or Stepped Headers???
  152. What are the best header gaskets/ bolts?
  153. site with lt1 / ls1 sounds with different exhaust systems
  154. High Flow Cat vs. No Cat
  155. new a pair of band clamps help
  156. Exhaust clip of my 86 IROC-Z w/ edelbrock headers
  157. Installing Headers
  158. Anybody have Magnaflow catback with CME??
  159. LS1 cat-back on an LT1
  160. bolt-on rwhp
  161. what size band clamp for MAC Headers primary slip fit
  162. Pacesetter Mids on 96 LT1-Check Valves won't fit.
  163. Borla Catback On Stock LT1 Video!
  164. Exhaust gas temperature
  165. spark plug access
  166. true duals with tunnel brace mounted TA
  167. Cut out/s - How many where to place
  168. want that loud rumble???
  169. Y-pipe difference between manual and auto cars?
  170. *ADVICE* - headers/y-pipes
  171. Stock cat to Magnaflow 94109 sound clip
  172. What to buy??
  173. opinions on corsa exhaust
  174. Cut OFF That Catalac Converter
  175. mac cat-back
  176. How much will it cost?
  177. borla exhaust
  178. x-pipes
  179. e-cutout stuck closed
  180. exaust cutt outs?
  181. suggestions on a loud sounding exhaust
  182. True Dual 3" dumps before axle, which hangers?
  183. After Converter cut-off
  184. Finished Pacesetter Mid & Magnaflow Catback/Hi-Flow Cat install
  185. Y pipe help
  186. long tube headers on an LT1
  187. Loudmouth 2.5"?
  188. exhaust system tuning...
  189. cheap/great sounding exhaust!
  190. where to buy pacesetters?
  191. new to board
  192. SLP 2otl or Magnaflow?
  193. Dual cat cat-back system on a single cat car? How?
  194. flowmaster to loud
  195. Exhaust Choices?
  196. Fuel line clearance with pacesetter ORY
  197. Tune Question.
  198. Size Of Collector Gasket Plz
  199. Hurry for emissions!
  200. Anyone test LM I vs LM II at the track ??
  201. Ne one running Borla X1 race mufflers?
  202. Using exhaust gasket material with Band Clamp?
  203. LS1 hanger on LT1? for gmmg exhaust
  204. After Pacesetters mids install i have leak
  205. Need Help Installing a 3 inch Cutout on a stock cat back ?
  206. cats
  207. which header gaskets are you using?
  208. Headers DONE!!!
  209. pacesetter o2 extension kit?
  210. true duals
  211. Header Fit Question
  212. doing LTs: bullet vs. magnaflow
  213. Muffler recomendations for ORY DUMP!
  214. Anyone ever connect ORY to stock catback?
  215. Supercharger installed... Need help upgrading exhaust!
  216. y pipe bolting to I pipe
  217. exaust question
  218. Is my car too Low.....
  219. Whay should I do?
  220. New guy needing good information
  221. price for long tubes
  222. SLP Loudmouth
  223. Y-Pipe Diameters
  224. Got an E-cutout, please help me out.
  225. Header gasket replacement
  226. gutting out the catalytic converter
  227. flow or bullet
  228. long tubes=retune
  229. Torque Specs on header bolts?
  230. pacesetter ory and stock catback?
  231. Remove Cats 96 Z
  232. Ory Vs Xpipe?
  233. SLP Headers and Loud Mouth-- TOO LOUD??
  234. slp website
  235. Just put in my cut out today
  236. Kook's Customer Service.....
  237. exhaust setup?
  238. Where is the cheapest place to buy Pacesetter lt's
  239. Magnaflow or Hooker
  240. Cutting exhaust
  241. New Exhaust
  242. Shopping for a new exhaust system
  243. Borla Stainless Steel Rear Section
  244. AIR injection question.
  245. open headers at the track?
  246. The bomb
  247. Just went to a Hooker....
  248. High flow cat??
  249. 1993 Camaro Z28
  250. Inlet size?
