y pipe bolting to I pipe
Old Jun 19, 2007 | 12:13 AM
ROUDA's Avatar
Im getting pacesetter long tube headers for my 95 Z28. How dose the y pipe bolt to the I pipe I was just thinking how does that go together will i need to get a pipe made to fit them together. or is there a flange on th y pipe that will bolt to the I pipe where the cat did. I have 1 cat on my car just to let you know. Thanks.
Old Jun 19, 2007 | 12:56 AM
95LT1conv's Avatar
LTs completely change the location of the stock catback. You will no longer be able to run the stck cat in its current location. Your I-pipe will run right beside your driveshaft.
Old Jun 19, 2007 | 11:51 AM
2000GTP's Avatar
The Pacesetter y-pipe doesn't have flanges, it is a slip fit style pipe.
Old Jun 19, 2007 | 01:29 PM
ROUDA's Avatar
So What Do You Have To Do To Make It Connect.
Old Jun 19, 2007 | 03:56 PM
2000GTP's Avatar
What are you connecting it to, stock exhaust, aftermarket catback?
Old Jun 19, 2007 | 05:36 PM
ROUDA's Avatar
aftr market flowmaster cat back.
Old Jun 19, 2007 | 05:56 PM
2000GTP's Avatar
You could have a shop weld a flange onto the y-pipe and connect them that way. Or you can remove the flange from the Flowmaster if it has one, and try to connect the pipes that way and secure them with either a u-clamp or band clamp.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
MadMav
Feb 6, 2015 11:02 PM
thenewkid
Nov 18, 2014 12:57 PM
