got my car back with cut out
Old Aug 21, 2007 | 12:54 AM
derbs's Avatar
I just got car back tonight and opened and closed the cut out and noticed that the cut out is leaking are they supposed to or are do they seal tight??
Old Aug 21, 2007 | 05:27 PM
White96Z28's Avatar
They all leak... Unless they actually drop your exhaust down, there's no way to get the weld all the way across the top.
Old Aug 21, 2007 | 06:54 PM
shock6906's Avatar
I'm not sure what exactly a cutout's exit looks like, but maybe you could get a header collector gasket to seal it up.
Old Aug 21, 2007 | 11:37 PM
derbs's Avatar
Ill see and look at it some more and see if i can track it down.
Old Aug 22, 2007 | 05:15 PM
White96Z28's Avatar
It should use a standard collecter flange gasket, but don't be suprised if it still leaks even with a good gasket. Generally they weld it in without dropping the entire exhaust, so there will be a hole in the top where the cutout mates with the I-pipe because the body gets in the way of the welder.
Old Aug 25, 2007 | 01:11 AM
mrmint69's Avatar
Put some aluminum foil around it and use a cheap hose clamp. I used a 1 foot piece and folded it up to about 3/8 of and inch and no leaks.
Old Aug 25, 2007 | 08:20 AM
93LEETZ's Avatar
I took mine to a local shop and had the guy install my cut-out. He welded the entire cut-out in place without dropping the exhaust.. he used a mirror to weld over the top. It never leaked.
Old Aug 25, 2007 | 08:39 AM
Z-RATED94's Avatar
Same here. Although I have used the aluminum foil trick for a different spot in the exhaust system. That works too.
cmdeshon
Dec 12, 2014 10:51 PM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
