I feel like such a......
Old Aug 22, 2007 | 09:01 PM
livewire516's Avatar
These exhaust manifold bolts aren't budging and I don't have the clearance for a larger breaker bar/ cheater bar. Would a 1200 in/lb electric impact driver be enough to massage them out? Wow, I just realized it's in/lbs not foot lbs. Is a 100 ft/lbs enough? I feel so dumb asking but an impact drive/wrench is a route that should work.
Old Aug 22, 2007 | 09:08 PM
camarozz95's Avatar
get some pb blaster spray down the bolts with that stuff and they will come right out/
Old Aug 22, 2007 | 09:11 PM
seawolf06's Avatar
Yeah, definitely spray them well or you'll be looking at half a bolt in your head.
Old Aug 23, 2007 | 12:28 AM
I'm already using some sort of rust-penatrating lubricant. I managed to get almost all of the off, now... i cannot fit even my smallest wrench between the exhaust manifold bolt and the power steering assembly. It seems like I already answered the question but... do I have to remove the PS box to access that bolt?
Old Aug 23, 2007 | 07:38 AM
BassProCamaro97's Avatar
Use a piece of conduit pipe on the end of your ratchet to gain more leverage.
~Jim~
Old Aug 23, 2007 | 09:12 AM
wrd1972's Avatar
PB blaster, lots of it and NO power tools.
Old Aug 25, 2007 | 01:08 AM
mrmint69's Avatar
I made an attachment to add to the wrench and it was nothing after letting the PB Blaster soak in.
Old Aug 25, 2007 | 08:37 AM
Z-RATED94's Avatar
Yep, great stuff. You just have to let it soak in for a day or two, if there really rusty.
Old Sep 29, 2007 | 11:51 PM
sn8ke eatr's Avatar
wear gloves or wrap some towel or tape around the wrench. anything to not make the wrench dig into your hand so much. you can pull harder that way
Old Oct 2, 2007 | 08:01 PM
wildweasel's Avatar
Are you turning the ratchet counter-clockwise? Just kidding.
Old Oct 2, 2007 | 09:07 PM
streetracerx's Avatar
ya while putting my headers on we found a bolt busted off in the head...we didnt do it. oh well 7 bolts is holding up just fine :P
Old Oct 3, 2007 | 11:23 AM
bufmatmuslepants's Avatar
PB blaster and LOTS OF IT letting it soak for a couple days. another way to get a little more room to get more leverage on the wrench is to hold your motor up with a hoist, take out the motor mount bolts, and jack up the motor a little bit. to get all of my bolts off it took a bit of adjusting with the hoist to get the right amount of room for each bolt. just BE CAREFUL and dont snap a bolt. and you can always try a torch to heat up the bolts if nothing else works.
Old Oct 3, 2007 | 12:00 PM
Ok4thGen's Avatar
The idea is to heat the metal around the bolt not the bolt itself, as heating the bolt itself would just make it further expand and be even harder to get out. heater the metal around the bolt will make it easier.
Hal Fisher
Sep 30, 2015 09:03 PM
Bxlt1
Sep 29, 2015 03:18 PM
colts0455
Sep 27, 2015 01:07 PM
greenzee28
Sep 25, 2015 04:29 PM
