Long tubes hit motor mount
Old Jul 31, 2007 | 10:12 PM
silverz28's Avatar
I just got my Pacesetter Long Tubes on my 96 Z28. I havn't started it up yet. They are laying on the motor mount on the passengers side. And, the collector in sorta forced up against the floor board on the passengers side. Do you think this might be a problem when the engine is shaking around? And, won't the floor get hot on that side since the collector is hugging the bottom of the floor? Should I worry about the carpet?
Old Aug 1, 2007 | 01:40 PM
InsuranceGuy's Avatar
If you have the headers bolted on, just pull down on
the end of the collectors just enough to slightly bend
the tubes to give enough clearance under the car. If
the tubes are still contacting the motor mount, you
may have to remove and notch them.
Emil:93Z,383,Vortech,NOS,w/methanol
Old Aug 1, 2007 | 03:05 PM
2000GTP's Avatar
If the motor mounts are worn out, that can lead to some clearance issues. Otherwise, some people have had to pull out a dremel and notch the mount a bit to give some added clearance.
Old Aug 1, 2007 | 10:45 PM
silverz28's Avatar
They are poly mounts. I sure hope I don't have to pull it out and notch it.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
