How can I tell if my CAT is clogged?
Old Aug 20, 2007 | 11:09 AM
CheshireCat's Avatar
I have my y pipe out and I'm going to change my O2 sensors.
Is there any way to test the flow of the CAT?
I'm not inclined to gut the CAT or put in a straight pipe...
Old Aug 20, 2007 | 11:54 AM
rexcellent's Avatar
If it is clogged, you will definitely be able to tell. Take the car for a spin and when you come back it will be glowing bright red. Also, it will run like SH*T!
Old Aug 20, 2007 | 12:26 PM
Moshbmx1's Avatar
I had a solid blanket of smoke behind me when my got completely clogged
Old Aug 20, 2007 | 12:30 PM
Pyrodawg's Avatar
lets see when mine clogged i had MAYBE 100whp i could put my foot to the floor in any gear and it would take forever to accelerate, i could hear the back pressure, i thought i had actually blown the motor
Old Aug 20, 2007 | 12:39 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
When I've had a cat collapse, my car wouldn't rev past 1K and it had absolutely no power. The exhaust manifolds were also glowing a tad when I finally made it home.
Old Aug 20, 2007 | 01:13 PM
Okay, thanks... Mine hasn't displayed those symptoms...
THe Cat has been rattling, but I can rev the motor and none of the exhaust has been glowing...
Old Aug 20, 2007 | 01:46 PM
'94 Bad A Z28's Avatar
If it's rattling it could just be coming apart from being so old. Disconnect it and drop it down and shake it around if anything comes out that is your problem.
Old Aug 20, 2007 | 02:13 PM
camarozz95's Avatar
also check the heat shield it rattles easily and can be mistaken for a bad cat.
Old Aug 20, 2007 | 02:48 PM
I had the y pipe out so I looked at the heat shield and it is tight...
Also I checked the honey comb inside and it appears to be intact...
I did notice that the entire honney comb has a little play inside the casing...
Just for laughs, I hooked up a 8 hp shopvac to the cat side of the y pipe and it wasn't restricting the airflow at all...
Old Aug 20, 2007 | 03:20 PM
BTC's Avatar
BTC
You could also check your tailpipes for what would appear to be metal shavings.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Sep 11, 2015 09:44 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
