Is replacing driveshafts difficult?
Old Aug 25, 2003 | 10:40 AM
john97z28's Avatar
I have an aluminum driveshaft waiting to install on my Z. I was wondering if it can be done on jackstands/ramps. What all do I need to disconnect? (torque arm, axle, etc.)
Thanks.
Old Aug 25, 2003 | 11:38 AM
rskrause's Avatar
Moderator
The only trick to it is to avoid overtightening the U-bolts. 20ft-lbs is right.
Rich Krause
Old Aug 26, 2003 | 02:06 AM
AL SS590 M6's Avatar
Moderator
Re: Is replacing driveshafts difficult?
Thanks.
The answer to your first question is yes and make sure the car is firmly blocked so that it can't roll.
All you need to do is unbolt the bolts clamping the u-joint to the yoke on the front of the rear end. Then slide the driveshaft out of the transmission. Reverse to install the new shaft using the torques that Rich mentioned.
Old Aug 26, 2003 | 01:08 PM
john97z28's Avatar
Thanks for the info! I plan on tackling it this weekend.
Old Sep 2, 2003 | 02:55 PM
john97z28's Avatar
Install went very smooth. Thanks again.
-John
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jazsun
Dec 29, 2014 12:14 PM
