Moser 9 inch Question
Old Aug 16, 2003 | 10:29 AM
klbjoc's Avatar
Just put a 9 inch with Detroit locker in my car. It is VERY loud! I was told the locker would be alot louder but this is crazy.
Anybody here have this set up, and is yours loud?
Kevin
Old Aug 16, 2003 | 11:52 AM
rskrause's Avatar
Moderator
Re: Moser 9 inch Question
Kevin
I'm guessing the locker is in a car that sees significant street time, otherwise why would you care about noise? I don't think there are too many people who would care to run a locker on the street. But except when it locks and unlocks, in which case it makes a god awful clunk, it shouldn't be terribly noisy. Of course, it's hard to diagnose a noise without hearing it. If it whines, the ring and pinion setup should be checked. If it clunks, that what they do.
Why did you get a locker? Just curious. I suppose a race car, that very very rarely goes on the street, would be a logical use. Otherwise
Rich Krause
Old Aug 16, 2003 | 01:52 PM
RacinZ's Avatar
Yes if its a clunking noise when your turning then thats ok. Whine noise I would check my gear lash then, to loose or to tight. Will wear out a set of gears real soon. If you catch it before a wear pattern forms on the gears then you can correct it.
Old Aug 17, 2003 | 12:08 PM
klbjoc's Avatar
It is not really clunking that is loud it`s the whine of the gears. It makes noise when you accelerate and when you let of the gas. I didn`t know if any of this could be because of the locker or just the set up on the ring and pinion. I have heard that Moser tends to have some loud rears.
The car is driven on the street a little bit but for the most part is just raced. It has a full cage and no carpet or rear seats, so I guess that would make it easier to hear any rear end noise.
I guess I will call Moser and see what they have to say.
Kevin
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
TitoPR221
Jan 2, 2015 03:51 PM
kev93z28
Aug 19, 2002 12:48 AM
