Are all 4th gen DS yokes the same O.D. diameter?
Old Aug 15, 2003 | 01:02 AM
Z95m6's Avatar
I need to build a reluctor ring to go on the driveshaft yoke of my Z so i can have ABS with my 8.8. I need to find a yoke out of a junk car so i can have a machine shop make me a gear to go over it? Will one out of a V6 car work? or a LS1? I would think all 4th gens would be the same outside diameter. The only diff would be the splines on the inside correct?
Old Aug 16, 2003 | 12:06 AM
OneFlyn95z28's Avatar
Most 4th Gen yolks are the same. Not sure on the two piece 3.4 shaft but I think it is also.
I would go get a new one(like $50) and have it machined. they do not have the harmonic ring on them and will give more room to install your ring
Why not try to piggy back off the Speedo Sensor?
Good luck!
Old Aug 16, 2003 | 12:37 AM
Z95m6's Avatar
i checked on getting a new yoke and dealers want 180 for one. I don't know where else to get one. I called the local Fbody salvage yard and he only had one for a automatic and i am not sure if that will work.
Old Aug 16, 2003 | 08:52 AM
Give Arron Spitzer a call at Randy's Ring and Pinion.
You can find the number in any car mag
Arron can be found 1.800.347.1178 #5579
brothaslide
Jan 9, 2016 12:11 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
detroitmuscle
Jul 31, 2015 04:21 AM
realistyc
Jul 28, 2015 07:32 PM
jbc3
Jul 28, 2015 12:24 PM
