putting in rearend gears
Old Aug 23, 2003 | 05:01 PM
ddlouhy127's Avatar
are rearend gears hard to put in, how long does it take? 2.73 to a 3.73. thanks
Old Aug 23, 2003 | 05:35 PM
Got-LT1's Avatar
If you are somewhat experenced and do your ressarch and have the right tools, it is fairly easy. It took me a full day by myself to do it.
Old Aug 23, 2003 | 10:29 PM
Cmr0z28's Avatar
umm....i would NOT recommend attempting a gear install unless you have experience and the right tools....
Old Aug 23, 2003 | 11:09 PM
Brent94Z's Avatar
Super Moderator
I'll move this over to the Drivetrain forum for ya...
Old Feb 7, 2004 | 11:22 AM
camaros_4_lfe's Avatar
ok instead of starting a new thread ill revive this one
im swapping 3.23 to a 3.73 gear in bout a month or 2
i want to do it myslef
what tools do i need to get ill buy em...i ahve good automotive knowledge but know not allot about rears at all..
whats involved?....where should i get the gears from?? and is there a write up on it anywhere?
Old Feb 8, 2004 | 03:04 AM
94ZRiCeKiLr's Avatar
trust me if you dont have a background in setting up rears, get it done professionally or at least have someone who has experience help u out....the tolerances are so tight and the gears have to setup absolutely perfectly or theyre going to whine and/or fail completely...
Old Feb 8, 2004 | 05:43 PM
ismokerice's Avatar
So what special tools are required? I think all you need is a dial indicator, some patients, and a torque wrench. I am really tired of this "you can't do that yourself" attitude. I am going to do it myself, and if I **** it up, I'll do it over. For the price you pay someone to do it you could learn how to do it yourself. Worse case scenario is you buy the parts more than once.
Old Feb 8, 2004 | 07:29 PM
Black6SpdTA's Avatar
Amen! And figure, for a $200 install, that's another set of gears if you screw yours up!
I think you need a pinion depth tool as well. Look around www.drivetrain.com
Needless to say, in 2wks I'm attempting the install of my 4.10's
Old Feb 27, 2004 | 04:54 PM
sleeper94z28's Avatar
its acually not that hard to do youself all you need is adial indicator and some patience, i had to take the pinion to machine shop to get the new bearings and shims pressed on, look it up on the internet and there are some good step by step instuctions. come onin only 18 and i did it.
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
ModdedNerd
Dec 18, 2014 10:52 PM
