Moser 12 w/TCS install?
Old Aug 17, 2003 | 02:31 PM
jnjspdshop's Avatar
I have a question about installing the axles in a customers Moser 12 bolt I have in my shop. The vehicle has 4 channel ABS/TCS so it has the tone rings on the axles. Now there isn't much clearance to tighten the caliper brackets. The way it is designed you must use the Moser supplied T bolts, but the nut is so far recessed in the hole it is impossible to tighten. So I was just wondering what everyone else has been doing. The only thing I can think of is instead of using 1 washer behind each nut adding another 2 grade 8 washers to bring the nut out of the hole a bit to be able to tighten it with a box wrench
Old Aug 17, 2003 | 05:57 PM
rskrause's Avatar
Moderator
Get a short socket with wrench flats and cut it down if needed.
Rich Krause
Old Aug 17, 2003 | 08:32 PM
Grover's Avatar
I used a 1/4" drive 9/16" socket to tighten the nuts for the T-bolts and it worked great.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
ddr698
Jan 9, 2015 10:05 AM
