Aluminum Drive shaft?
I have a 95 trans-am and a stock DS> I was wondering what are all the benafits of haveing a aluminum DS. Is there all that much difference. and are there and down sides to the whole thing.
Main advantage I see with the aluminum shaft is less vibration and a little weight savings. But if your stock steel ds doesn't have any vibration I'd keep it. The steel shaft is stronger than the aluminum ones. I've seen many snapped LS1 driveshafts.
I'm running the times in sig with the stock steel ds. So it works for me.
Rich Krause
if you decide to upgrade driveshafts, to one stronger then a 1LE or LS1 aluminum, i recommend www.dennysdriveshaft.com
taner
Sep 9, 2002 11:36 PM
