Is a 12 bolt the only solution to our problems??
Old Aug 26, 2003 | 04:57 PM
JeremyKweens's Avatar
Is there other solutions besides the 12 bolt to cure our mad rear end snapping disease???
Old Aug 26, 2003 | 06:19 PM
rskrause's Avatar
Moderator
The two practical solutions are a 9" or a 12-bolt. I understand a Dana 44 can also be adapted, as can a variety of other rear ends depending upon your skills and budget. But the only "bolt-in" solutions are a 12-bolt or 9", both of which can be had with the correct mounts, brackets, etc.
But if you are asking if the 10-bolt con be beefed up sufficient for drag racing with sticky tires, the answer is "no".
You may want to post this in the "Drivetrain" forum for some other answers.
Rich Krause
Old Aug 26, 2003 | 11:37 PM
Brent94Z's Avatar
Super Moderator
I'll move this over to the Drivetrain forum
Old Aug 26, 2003 | 11:44 PM
bowtiepwr's Avatar
>As far as I know ... you can't have ABS with the 9" rear , but with all (Strange, Moser,KTRE) all are ABS friendly .
unless this has changed of course .
Old Aug 26, 2003 | 11:54 PM
CamaroBoy96Z28's Avatar
If I'm not mistaken some 9" rears are available with ABS now. I want to say that the Moser 9" is ABS compatible now maybe someone can verify it.
Old Aug 27, 2003 | 12:31 AM
johnny o's Avatar
The Moser 9" can be had with 4 channel ABS (Most 93-97 AUTOS and 98-02 cars?) and the 12 bolts 3 and 4 channel support is out there. There is also a place doing Ford 8.8" bolt ins and say ABS support is coming but not available yet. This can be had at http://www.extremechassis.com/ but I feel it is not worth the price when a 12 bolt can be had for little more.
Old Aug 27, 2003 | 07:06 AM
car_ramrod's Avatar
what exactly in the 10 bolts make them so weak? Which parts usually fail? I havent ever blown one up but im guessing its not the ring&pinion. Is it the axles themselves and or their splines? Im thinking it has more to do with the posi, side, and spider gears. If that is the case i know the cheapest solution: it only involves a welder and a case of beer. But thats only for a budget race only car, hehe. But seriously id like to know what the problems with the 10 bolt are and why there isnt a better solution than swapping in a whole new rear-end. Thanks.
Bubba
Old Aug 27, 2003 | 01:15 PM
jdizzell's Avatar
Its the pinion that breaks, they are to week for hard launchs.
Old Aug 28, 2003 | 12:21 AM
Yup when my rear went, my pinion seal was leaking and the pinion gear was messed up. This was before I was into drag racing at the strip and modding my car. The car was bone stock and I was driving 300 miles from my cottage back home. Basically I drove most of the way from the north of Michigan's lower peninsula all the way back to Detroit with an annoyingly loud noise coming from my rear in stand-still traffic and 95* heat down I-75.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
edman
Jan 25, 2015 02:41 PM
Catmaigne
Dec 25, 2014 12:16 PM
