sticking trany
Old Aug 22, 2003 | 11:56 PM
cwdouglasville's Avatar
Question sticking trany
98 Z28 6spd convertible, My clutch and trany opp fine under normal driving conditions, very smooth. However when I get on it the trany will either stick in gear or will not let me shift into another without some force. Also the clutch pedal will not come all the way back. I know the clutch disengages because of the change in the engine RPM'S. Any help will be appreciated.
Old Aug 23, 2003 | 02:28 AM
AL SS590 M6's Avatar
Moderator
It's nothing that a new clutch, flywheel, pressure plate, slave cylinder, and master cylinder won't solve.
The clutch system in the 98s is horrible for any kind of performance driving exhibiting the symptoms that you describe.
That's why GM has upgraded all of the involved parts except for the flywheel.
If you want to drive it hard you will need to upgrade.
Quickss96
Jan 29, 2016 05:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
Boss002
Jul 24, 2015 10:47 AM
dolfan324
Jul 17, 2015 10:34 PM
