help me build a strong 10 bolt
Old Aug 17, 2003 | 01:00 AM
amean94ta's Avatar
my rear in clunking and when i launch it throws the car to the right more than left. so i know the posi is going i dont have the money for 12 bolt now so i need to get this fixed asap. i need a posi i was thinking a locker but what do you experts say? i need new axels i was thinking the moser's i am runing a 4:10 in a a4 with dr's so can you plese help me
Old Aug 17, 2003 | 03:12 AM
rskrause's Avatar
Moderator
Most people find a locker completely unaccetable in a street car. If you car is 90% strip with an occasional ride on the street, you may want a locker. Otherwise, stay far away from one. Especially if you have never driven a car with one installed. There is a very loud, quite violent clunk when it locks/unlocks. No fun at all, IMHO.
Why do you say you need axles? If you do, the cheapest solution might be to buy a complete rear from someone who has upgraded, install your 4.10's and you will be good to go.
Rich Krause
Old Aug 17, 2003 | 09:32 AM
RacinZ's Avatar
hey Rich, I'm kind of wondering the same thing. On Dr I will be running 10's and n2o mine is a auto. I neverc wll have slicks on it so I will have a little spin. Wondering should i use replacement Moser axles, and a new posi carrier, I forgot the name of the carrier but its a takeout unit. I will be using 373. Axles 225, posi 120, gears 100 set up 50.00 (friend) Under 500 or I can buy the Moser for 895 without a center. I have a few centers laying around even with gears. About 1000. I have never used a 10 bolt, do you think it will work with Dr's any insight would be appreciated as I have noticed your answers are prety much on the money
Old Aug 17, 2003 | 01:34 PM
amean94ta's Avatar
i dont care about the noise i just want something that will lock the rear solid and still be able to turn corners and i think i need axels because there is a clunk in my rear and it is not the ring and pinion
Jun 6, 2015 08:27 AM
maybe2fast
Mar 16, 2015 09:45 AM
transam_388
Mar 15, 2015 11:53 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
