Do I need control arm relocation brackets for Strange 12-bolt?
Old Aug 20, 2003 | 10:37 PM
1loudz's Avatar
im puttin in my STRANGE 12 bolt tomorrow, and the control arm brackets have only one hole available. the car will have eibach sportline springs installed at the same time as well, so it will be lowered quite a bit. do the aftermaket rear ends already have a bracket that is the right spot for lowered cars or do i need a new bracket? any experience with this rear-end?
Thanks,
Ryan
Old Aug 20, 2003 | 10:57 PM
Brandon 95 Z28's Avatar
Might want to move this to Drivetrain forum Ryan, you will probably get more responses. Good luck with the install. What gears does the rear have? I am putting in my 4.10's soon.
Brandon
Old Aug 20, 2003 | 11:12 PM
The Strange LCA mounting bracket is identical to the factory 10-bolt mounting bracket, and located in exactly the same place. If you drop the body with Sportlines, I can't see how you could avoid installing a set of relocation brackets to restore the geometry, and keep the axle end of the LCA below the body end. You could survive without them, but I would expect traction to be "limited".......
Spohn LCA relocation bracket on a Strange 12-bolt
Old Aug 20, 2003 | 11:38 PM
1loudz's Avatar
Brandon........whats up man, i tryed to call ya but ur phone's disconnected. anyways the rear has 3.73 and all the options you can get on it...... auburn posi, c-clip eliminators, alum. case, upgraded axles, etc, etc. im gettin it used, and im havin to do all the work, so i have the other guys car too. i worked on it for about 4 hours today, and got both rears and suspension out, tomorrow ill put it all back together and do the front suspension.
give me a call if ya get a chance bro.
late.
thanks injuneer, ill order them right now!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
