Need New Clutch. Which one?
Old Aug 19, 2003 | 10:26 PM
therealmagyver's Avatar
I don't need a high performance one that is going to give out after 25,000 miles and cost an arm and a leg. I will get a stock one if have too, but which ones do you guys suggest? How much and on average how long do they last? I got 80,000 out of mine. I got the car with 62,000 and I don't know how bad the previous owner beat on it, but I beat on it for the 18,000 miles I ran it.
Old Aug 19, 2003 | 11:59 PM
ChrisLS1Bird's Avatar
Re: Need New Clutch. Which one?
Originally posted by therealmagyver
I don't need a high performance one that is going to give out after 25,000 miles...
The opposite would occur with a high performance clutch. We're not talking about tires here. If you want something that will last until you get rid of your car, go with a hi-po...McLeod, Star Spec stage 2 or 3, RAM...
The problem with choosing something like that, however, is that you need to upgrade your clutch master and slave cylinders. So, toss in another $400 to the price of parts+labor...you're looking at $1000-$1500. You may need to upgrade the clutch slave cylinder, regardless of the clutch you choose.
The factory Z06 clutch kit sells for around $309 through paceparts.com and other sites. That may be the best compromise for you. But if you don't ever want to do this again, choose something stronger.
Old Aug 20, 2003 | 12:21 AM
SSpdDmon's Avatar
If you don't plan on major upgrades in the future, I'd say go with the Z06 setup from www.gmpartsdirect.com - part # 12570806. That # is a package (I believe) that gets ya the flywheel, pressure plate and clutch disk. All you need to do is pick up the throw out bearing I think. Can't remember for sure though. Check with your mechanic.
Old Aug 20, 2003 | 12:38 PM
I thought performance clutches don't last long. Well this is good news.
Old Aug 20, 2003 | 11:03 PM
AL SS590 M6's Avatar
Moderator
Performance clutches don't get a good rep for longevity because they get beat on so bad. For instance a Star stage 3 in the buddys twin turbo car only lasted 2 years. But 2 years behind a motor that puts 550+ hp to the rear wheels. Pulling 1.53 sixtys on sticky tires in a 3800lb. car. 2 years was great
A performance clutch used in a daily driver should last a good long time
Old Aug 21, 2003 | 12:44 AM
Talking
That sounds good to me!!
Old Aug 21, 2003 | 03:02 AM
GM PART # 12570806
CATEGORY: Engine Flywheel
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $527.86
OUR PRICE: $300.88
DESCRIPTION: FLYWHEEL package
this flywheel package comes with the following: flywheel, pressure plate and clutch disc.-----this kit is designated for 2001-2003 corvette Z06 equipped with the LS6 engine with MM6 trans.
Does the MM6 the same as MN6? MN6 is manual 6 speed, so I the gmparts site meaning MM6 to be a manual 6 or is the MM mean something else? I'm ready to order online tomorrow morning after this is answered. I will call if I have to, but I'm trying to save time...I hate staying on the phone forever which I'm pretty sure will happen when I call their customer service line.
Old Aug 21, 2003 | 03:05 AM
Talking
I just found out what those codes are. They are RPO codes. I just want to make sure I am getting the right z06 clutch & flywheel for my car, so I am being **** about it.
MM6 Transmission, Manual 6-speed, Borg Warner
MN6 Merchandised Transmission, Manual 6-speed Provisions
Bxlt1
Sep 29, 2015 03:18 PM
raroz28
Sep 8, 2015 06:10 AM
karpetcm
Aug 14, 2015 03:02 PM
BlackVelvet
Dec 30, 2002 11:26 AM
