Shifting in an Automatic
Old Aug 24, 2003 | 01:44 PM
JacobK's Avatar
Hey everyone..i have a question, i have heard two different sides to this question..Lets say im sitting at a light and this guy wants to race me..(i know street racing not smart but just saying).I drop it down into first, and then shift to 2nd about 5K, then shift to drive at about 3500, then OD..at about 3K...will this destroy my trans? i heard that some people say it will...some say it wont.
Also what about everyday driving, and i drive it like its stick 1st to 2nd to D to OD...will that mess up the trans? im not talking about like redlining it then shifting...like shifting at about 3K...Will this screw it up?
Sorry if this is a dumb question, but it has been bothering me, and i was just wanting to know the best possible answer.
THANKS ALOT EVERYONE
Old Aug 24, 2003 | 02:01 PM
anaik's Avatar
If you have the pedal to the metal and shift at 3K, the trans won't shift till it reaches what's programmed in the PCM.
Old Aug 24, 2003 | 02:44 PM
StreetZ's Avatar
There's really no reason to maually shift it....the only exception is maybe keeping it in D instead of OD for the purpose of running the 1/4 mile.
Old Aug 24, 2003 | 03:11 PM
rage366's Avatar
nope...ur tranny will be just fine.
that's just an old wives tale.
your shifter cable might not like you anymore, but you'll be fine...
Old Aug 24, 2003 | 04:48 PM
JacobK's Avatar
do most of you guys drive around in drve or OD?
Old Aug 24, 2003 | 05:00 PM
Mike-94 Formula's Avatar
That's OK unless you're decelerating in the lower gears,if you do that enough you can get ready to replace the overrun clutch like mine needs.All of the sudden you wont have any engine braking in low and 2nd and maybe 3rd but I haven't tried that yet since I'm now babying mine untill I can go in the trans.
Old Aug 24, 2003 | 05:16 PM
Zack's Avatar
i drive in D since I dont have OD
thewinner's Avatar
Ive always been told its fine to upshift an auto tranny like this, but not downshift unless it has a manual valve body.
Old Aug 24, 2003 | 06:43 PM
FacelessZ's Avatar
Downshifting will ware your trans...upshifting won't hurt it...
Old Aug 24, 2003 | 07:11 PM
rage366's Avatar
drive in D? why?
only time i shift it into D or 2nd is when i'm about to stomp on someone...other than that, OD is good enough.
oh yeah...some ppl like to drive in D cause it makes their exhaust louder...as for me, i'd rather the cops say "there he goes," not "here he comes."
Old Aug 24, 2003 | 08:34 PM
12SCNDZ's Avatar
I build automatic transmissions for a living, and I usually shift my 700 ('93Z) manually (Unless I'm tryting to eat a Whopper from BK at the time).
I shift it at 6200 RPM's in 2nd and 3rd at the track...Don't need 4th...Even with the 4.10's. I drive the car around town in 1st, 2nd, and 3rd gear. The only time I use 4th is when I'm cruising at 65+, on the highway.
Frank
All-Trans Transmissions
Old Aug 24, 2003 | 08:37 PM
12SCNDZ's Avatar
BTW...I DOWNSHIFT mine, too. Don't tell my transmission my car has been running in the 12's for the last 3 years.
Frank
Old Aug 24, 2003 | 08:44 PM
KeVMaN's Avatar
Frank
Everything i've ever heard said its a bad idea to downshift an auto tranny
edit, is there anything you can do to an auot tranny to make it shift when you shift? because really, you're just setting the limit on which gear it will shift into automatically on a stock tranny. I've shifted manually a couple times and you have to time it right so you don't hit the rev limiter (as it takes a second or two to actually shift)
Old Aug 24, 2003 | 08:54 PM
12SCNDZ's Avatar
Rev limiter? I'd have to go a long way to hit my 6600 RPM rev limiter...LOL Have you still got the factory 5800 limit? My old Hypertech chip, and my new PCMFORLESS chips both do away with the limiter...They're in my MSD 7AL-2 now.
If you're bumping the limiter, you either need to raise it, or do some governor work in the transmission.
Wanna buy my old Hypertech chip? It went 12.82 @ 105.9 MPH in a completely stock motored '93 Z...With exhaust manifolds!
http://www.geocities.com/max_wylde/9...re_page_1.html
Frank
Old Aug 24, 2003 | 10:00 PM
WheelmanZ28's Avatar
bingo
