Unbalanced Driveshaft
Old Aug 26, 2003 | 09:37 AM
BlakeW5's Avatar
I've heard about the problems with the 93-96 driveshaft being unbalanced (supposedly fixed in 97 right?). How can I tell for sure if I am having this problem? My car doesn't vibrate, but I hear a "churning" noise coming from the driveshaft area every now and then. Is this the problem? Also, how much damage can it do? Or is it just a "ride comfort" type thing?
Old Aug 26, 2003 | 10:49 AM
BPS's Avatar
BPS
it's a ride comfort thing that occurs usually at higher speeds >75mph. I guess it could be serious if the balancing problem was extreme
Old Aug 26, 2003 | 10:53 AM
rage366's Avatar
you'd feel vibrations when ur cruising on the highway...
Old Aug 26, 2003 | 04:38 PM
VegasZ's Avatar
I have a 97 and was getting bad vibes above 85mph. I replaced the steel shaft with an aluminum GMPP one and the vibes were gone. If you have the steel shaft, your gonna have more vibe. Only way around it is to replace it with aluminum, or smoother yet carbon fiber.
Old Aug 27, 2003 | 01:47 PM
slayer6x6's Avatar
If you know someone with a dial indicator you can check it for runout. Im pretty sure the spec is between the .035-.040 range.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
