dfi and stock gauges? need help
Old Jan 23, 2008 | 07:40 PM
4SFEDZ's Avatar
ok is it possible to run an aftermarket comp (dfi) and retain the stock gauges? oh and this is a lt1 car, not sure if that matters!
Old Jan 23, 2008 | 07:44 PM
mdacton's Avatar
The volt,oil pressure and Temp will run without the stock PCM. The speedo and tach will not.
Just wire them and then you will have to ground the wire on the cluster. Depends on what year it is but all the wiring for the 3 plugs on the pass side kick panel are on shbox site
Old Jan 23, 2008 | 07:59 PM
4SFEDZ's Avatar
its a 94, so it is possible as long as i leave the stock pcm in?
Old Jan 23, 2008 | 08:27 PM
mdacton's Avatar
Is what possible?
Thos 3 I listed will work without the PCM......tach speedo etc. you will need the PCM
Old Jan 23, 2008 | 08:47 PM
4SFEDZ's Avatar
Originally Posted by mdacton
Is what possible?
ok by leaving my stock pcm in, i can piggy back the dfi and all my gauges will work!
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
Joes96z
Dec 13, 2014 07:48 PM
