How much h.p is the stock pcm good for ?
Old Feb 5, 2008 | 08:48 PM
crazycat's Avatar
Hi I am building a 95 383 with a good size turbo set up, my goal is 750rwhp. I dont know alot about the tuning but is my stock pcm going to be able to handle this ? or should I buy the fast system or somthing else ? thanks..
Old Feb 6, 2008 | 01:48 PM
JAB's Avatar
JAB
There is no limit as to how much power it can handle. It can only handle 7000 RPM max I think though.
Old Feb 6, 2008 | 02:01 PM
jsetzer's Avatar
It can run past 7krpm, but you are shooting in the dark because the tables only go up to 7k.
I won't say that you can't do boost and 750rwhp - Its been done - But I think it would be easier to use a different computer. I am partial though.
Old Feb 6, 2008 | 04:42 PM
crazycat's Avatar
I dont plan on going past 7000rpms, I dont think...But I will have large injectors..Just wondering if its worth the money, can I get a better tune ? will I be able to make more power ? thanks
Old Feb 6, 2008 | 07:43 PM
Lisa33's Avatar
were running 160lbs injectors, thats enough for 750rwhp++.
Stock PCM works OK but if you dont have any experience working widh it you be better of starting widh a aftermarket system.
You aint gonna se more HP at WOT widh a aftermarket EFI then stock but you properbly gonna get better driveability.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
thenewkid
Nov 27, 2014 09:41 AM
