Running rich?
Old Apr 20, 2008 | 08:45 PM
BCook839's Avatar
Running rich?
I sent my PCM to PCMforless.com to correct my speedo for 3.73 gears and to do their normal ignition and feul curve tricks to the PCM.
Im worried that it is running very rich now. The car is running strong and hard, faster than every, but my exhaust tips are very carboned up and black and it sucks the gas now also. But my biggest problem is that the oil pressure has dropped and I am affraid it is because unburnt feul is getting into my oil and causing my bearings to wear out.
Is their tune just dumping feul into the engine? Or is this just because they have the fans setup to turn on at 160 degree coolant temp and this low engine temp causes feul to not burn completely? Ive checked all other components that could be causing this problem and I'm almost positive that the tune setup is the issue. I do not have access top a scan tool of any sort to check feul trim or any other feul related level/measurement.
Ben
Old Apr 20, 2008 | 09:41 PM
jay_lt4's Avatar
invest in a scan tool, or a cable and data master,, it is the only way you can know what is going on with your engine/tune
Old Apr 21, 2008 | 12:53 AM
Cobra2k7's Avatar
Where can you buy those?
Old Apr 21, 2008 | 02:39 PM
The typical "tune" for a fairly stock setup is limited to leaning out the PE mode (~WOT) target A/F ratio. They don't just tune it to "dump fuel".
Sounds like you have something causing the A/F ratio to be elevated in closed loop (part throttle/part load) driving. A tune does not change the 14.7:1 A/F ratio for this type of driving. Could be things like excessive misfires, exhaust leaks before the O2 sensors, faulty O2 snesor, etc.
Data logging software may show you the problem. AutoTap is one of the systems available for the OBD-II cars, but there are otheres.
http://www.autotap.com/
http://www.auterraweb.com/software.html
http://www.obd2.com/
http://www.qcontinuum.org/obdgauge/
Old Apr 22, 2008 | 12:25 PM
BCook839's Avatar
Where is a good place to buy a decent quality air/feul ratio meter for a reasonable price, it seems like all of the digital readout guages are $300+.
Old Apr 22, 2008 | 10:16 PM
Kyle@CSS's Avatar
Or you could rent some dyno time. That would also help your tuner.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
