Link Error Pcm Scan
Old Mar 23, 2008 | 10:13 PM
gmantlr's Avatar
Question Link Error Pcm Scan
I HAVE A 95 Z28 THAT HAS A OBD2 DATA LINK CONNECTOR. I HAVE TRYED SEVERAL DIFFERENT SCAN TOOLS FROM CHEAPIE TO SNAP ON AND GENISES.NONE WILL COMUNICATE WITH PCM.ENGINE JUST BUILT AND ORDERED A TUNE INCLUDING PCM.WONT SCAN STOCK OR TUNED PCM.ALL FUSES ARE GOOD AND IT HAS POWER AT THE DATA LINK CONNECTOR.AND THE GROUND WIRE IS CONNECTED TO ENGINE FROM BATTERY OF COURSE AND FROM BODY. ANYONE HAD A SIMALAR PROBLEM THAT THEY FOUND A SOLUTION FOR? SHOOT ME A EMAIL AT gmantlr@yahoo.com
Old Mar 24, 2008 | 01:00 AM
2xLS1's Avatar
Are you using an OBD1 scanner even though the plug looks like OBD2?
Old Mar 24, 2008 | 12:08 PM
http://shbox.com/1/xraycable.jpg
Old Mar 24, 2008 | 12:35 PM
gmantlr's Avatar
pcm scan
So I Should Be Able To Jump The G And 5 Terminal And Watch The Check Engine Light Flashes Like The Older Style Obd1
Old Mar 24, 2008 | 12:55 PM
2001NBMZ28's Avatar
No, '93 was the last year for that.
Old Mar 24, 2008 | 01:09 PM
gmantlr's Avatar
So I Have A Obd1 Computer With A Obd2 Data Link Connector And I Cant Jump The G And 5 Terminal And Get The Check Engine Light To Flash Codes. I Have To Put Wire In The G And 5 Terminal And Then Connect The Wire To The Obd1 Scan Plug In Order To Read Codes Or Monitor Sensors. They Should Of Made It On Or The Other Obd1 Or Obd2 Not A Obd1 Pcm And A Obd2 Data Conector. I Wonder If I Will Be Able To Read Sensors With Only Connecting Two Wires Between The Obnd2 Data Plug And The Obd1 Cable?
Old Mar 24, 2008 | 01:32 PM
2001NBMZ28's Avatar
No personal experience with it but the obdi tool should work. You can also buy an optional adapter that fits between the obdi tool and the obdii connector - essentially does the same thing as the shbox link.
Old Mar 24, 2008 | 03:14 PM
gmantlr:
Please turn the "caps lock" off. When the site software sees all caps, it converts everything after the first letter of each word to lower case, and you end up with a screwy looking post that is hard to read. I think you escaped with all caps in the first post because you coded the "smiley" and your e-mail in lower case.
Old Mar 24, 2008 | 05:02 PM
Just use an OBD-I scanner with the correct adapter cable. Scanner manufacturers have this cable available. It's nothing new.
Old Mar 24, 2008 | 06:39 PM
gmantlr's Avatar
Thanks guys i figured it out with your help sorry about the capitol letter deal.
DirtyDaveW
Dec 1, 2016 05:37 PM
DSMKilla
May 26, 2015 10:10 PM
grgguy
17
Feb 23, 2015 07:57 PM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
