Shopping for a Wide band
Old Mar 27, 2008 | 10:25 PM
mdacton's Avatar
What should I look for?
Just need it for my drag car and would like to record a pass and replay it.....
What are my options? LM-1?
Old Mar 27, 2008 | 11:20 PM
96LT1TX's Avatar
I will be following this post... within the next few days it sounds like I will be using the delete knock sensor mod... finally.
Old Mar 28, 2008 | 07:49 AM
PoorMan's Avatar
I like the dynojet wideband commander. Comes with a gauge you mount in the car and not as complex as a LM-1.
Old Mar 28, 2008 | 08:19 AM
mzgp5x's Avatar
I as well have a DynoJet WB. It has also has a USB connection, and, can data log based on trigger point set_up. I do like the analog gage feature. It is great for low speed cruzing since you cannot always run data logs and spend more time disecting the data for solutions. I understand it is more expensive, but, the analog gage helps. I also have an autometer afr gage next to it on the "A" pillar. Also, the autometer gage is wired to DTDP toggle switch for easy selection of Rt/ Left O2 sensor input while driving (an idea from LJ). The WB afr gage works well with the idiot light colors of the autometer afr gage, so, you can get an idea of where each bank is running. B.
Old Mar 28, 2008 | 08:25 AM
Dual sensors, data logging (no extra "rpm" module needed), with "alarm" and ability to interlock to a relay (e.g. - shut down nitrous on lean A/F ratio). It's on my wish list.... but still a bit on the expensive side at $720:
http://www.altronicsinc.com/pages/o2alert.html
Old Mar 28, 2008 | 08:37 AM
dangalla's Avatar
i had a AEM UEGO in my last car, i liked it alot, anolog and digital out for logging and i nice gauge with a electronic led anolog sweep and led numerical output
edit : http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old Mar 28, 2008 | 10:39 AM
97WS6Pilot's Avatar
I have a Dynojet Wideband Commander. I had the silver bezel changed out for a black one by autometer and it looks like it was a factory install. Analog guages are definitely best for a wideband. It smooths out the needle and gives you useful info as you drive. It logs rpm, throttle position, afr, and map(all the keys for tuning). It also has a programmable light on the guage that I use for a shift light. Only downfall is I had to buy an MSD tach adapter to get the rpm logging to work.
Old Mar 31, 2008 | 12:35 PM
mdacton's Avatar
Thats a really nice unit, but expensive for what I want to do.
I just need something for N/A drag car.......I want the simplest cheapest thing I can get before this weekend
Old Mar 31, 2008 | 01:27 PM
97SS0594's Avatar
deff get the AEM UEGO! its easy to use and is very high quality, the innovative wideband is a pile of crap! ive had nothing but problems with mine. i have the AEM in my SS and the innovative in my Z28, i want to smash the one in my Z28 with a hammer as i dont think it has ever given me a reading.
Old Mar 31, 2008 | 01:35 PM
mdacton's Avatar
Can I log data with that?
I don't give a crap about a gauge, its in a race car so I need to log the data and come back to look at it.
Old Mar 31, 2008 | 01:44 PM
dangalla's Avatar
Old Mar 31, 2008 | 01:49 PM
mdacton's Avatar
Looks like just a gauge and sensor......How does it hook up/log etc. Tell me everything. I'm ready to spend my money. The local dealer can get it withing 2 days....so hurry up. I'm trying to run this weekend
Old Mar 31, 2008 | 02:21 PM
dangalla's Avatar
when i logged with it it was through maft-pro and there software tunerrt-pro on a turbo talon, not sure about a lt1, how does everyone else log with a wideband, i am sure it is the same. is there a aux imput for your logging software
you should just pm injuneer and ask him, i am sure he knows and would love to help you mike
edit: the gauge is actually the controller in that unit, there is two outputs from the gauge meant to be used for logging, it also comes with the sensor and the harness
Old Mar 31, 2008 | 03:04 PM
97SS0594's Avatar
it has a little port, you can log with it. i believe it comes with the cable to log too!
Old Mar 31, 2008 | 05:03 PM
dangalla's Avatar
yeah thats it, good price on it too. you will be happy with it
